New Navdata.db3 - 20130606
Started by orkney, June 07, 2013, 10:49:30 AM
orkney
Hello
Once again, The new Navdata Installer can be downloaded from the link below:
http://www.airnavsystems.com/download/ANRB/DBUpdater/ANRBDBUpdater20130606.exe
For checking your installation this one has 198,489 records.
Thank you
Andrew
Many thanks, Andrew and everyone else involved.
Great job, many thanks to all updaters.
imropes
Thanks again Fast download,no problems.
nortonbeak
You updaters are just wonderful:-)
Thank you
Northern Watch
Many thanks to all the Updaters.
Keith
Albatros
Many thanks for your great job
Paolo
anodes
Hi All have downloaded the link and ran the link, have checked in the data it appears not to have updated, only showing 82763 aircraft, what else do I need to do many thanks Stephen
Stephen,
It is normally the case that where this occurs that you have more than one version of Radarbox on your computer i.e you installed from the disk and have then updated to 3.13 or 4.03 at some stage.  The update will have went to the wrong version and you will either need to download and direct the install to the correct version or to use windows search to look for all the instances of Navdata.db3 on your computer and to move the new instance to the correct version data folder replacing the old one which is being used at present.
If you need any further assistance in doing this come back and I will try and talk you thorugh it.
anodes
Hi Alan many thanks for the info. You might have hit the nail on the head, I updated Win 64 Bit some while ago.  I will let you know how things progress.
Many thanks, Stephen.
anodes
Hi Alan, I have tired as you suggested, pointing the update to the older 2009 version. Looking back I have done some updates before with no problem. this where the update is going to;
C:\Program Files (x86)\AirNav Systems\AirNav RadarBox\Data\Data
running the 3.13 Ver of radarbox.
Many thanks Stephen
Stephen,  It should only go as far as Airnav Systems\Radarbox as it installs itself in the Data folder.
Remove it from Radarbox\Data\Data in to Radarbox\Data replacing the one in there and it should be OK
anodes
Hi Alan many thanks for above info, had a look around the files & found that there were two radar box programs one 32bit the 64bit, so decided to remove program and run the 64bit version so @ the moment I have 1086 aircraft, & running on 2.01 ver just trying to find the latest version!! Regards Stephen
#13
Here it is Stephen, its 500Mb or so http://www.airnavsystems.com/download/anrb/403/ANRB403Setup.exe
Re 32 bit and 64 bit, i think it is all the one programme but as it is a native 32bit i think windows does things, works its magic to enable it to run in the 64bit environment
Here are the 64bit drivers as well just in case, http://www.airnavsystems.com/download/ANRB/drivers/ANRB64bitDrivers.zip
If you are going to install the new version I would suggest you save your Mylog.db3 file as it has your current logs.  I would then uninstall everything else and once done manually delete all thats left.
When installing again it would be wisw to avoid the default install location and direct the install to c:\ to avoid windows virtual store problems.  Once installed replace your saved Mylog with the one installed and update the Navdata again
Have fun
anodes
Hi Alan, many many thanks for your time today, I have done as you suggested all works fine now, gets the old grey matter going. Thanks again, regards Stephen.
