Started by orkney, June 21, 2013, 02:28:12 PM
Hi Jason,
A6-EEK is the registration of the A388, I can only determine its route if it gives out its flight ID instead which should be UAE***
AFR4031 CYYZ-LFPG
UAL1668 KEWR-KSFO-KEWR
shouriken
A6-EEK flights from yesterday were UAE241/UAE242 (DXB-YYZ/YYZ-DXB).
After landing at YYZ (~2000Z) changed its flight id from UAE241 to A6EEK and kept it until ~0020Z. Then it changed to UAE242 at ~0140Z when started to taxi for departure.
Liviu
A.net JetPhotos.Net
RadarBox
Thanks for thr info Liviu
CYYZGUY
Hi Alan
VIR800P No route showing
40" LED Monitor
40" LED Monitor
Hi Jason,
I belive it is a positioning flight KMSP-EGLL.  The same ID was used around a week ago KJFK-KMSP.
CYYZGUY
#1460
Thanks Alan,
I have another one for you..
AWE481  No Route
AAL2251 No Route
AAL151 No Route
AAL1551 No Route
Can you check the routing of AAL1485?  It has just come in for a landing at CYYZ however the routing shows..
CYYZ-KMIA-MWCR?
regards,
40" LED Monitor
40" LED Monitor
Hi Jason,
AWE481 KDEN-KPHL-KDEN
AAL151 KBOS-KDFW-KBOS
AAL2251 KDFW-KBOS-KDFW
AAL1551 KORD-KBOS-KORD
AAL1485 KMIA-CYYZ-KMIA but I notedit routed to Grand Cayman a couple of times in August
Unkowns from yesterday:
* 101010  DETUR                                                       2013/10/18 13:26:46
* 38B9DB  FWBTJ                                                       2013/10/18 13:56:21
* 39C497  FHREX                                                       2013/10/18 10:02:52
* 3C6492  DLH056   EDDF-EDDV                                          2013/10/18 16:51:47
* 3C6492  DLH061                                                      2013/10/18 18:07:29
* 3C6492  DLH1M    EDDH-EDDM                                          2013/10/18 15:58:01
* 3C6492  DLH2TT   EDDH-EDDM                                          2013/10/18 16:18:25
* 3D2F23  DEQCH                                                       2013/10/18 12:31:57
* 3D3616  DESSS                                                       2013/10/18 10:26:44
   3D6001  DKBOB                                                       2013/10/18 13:00:31
   3E8EC3  PACK1                                                       2013/10/18 06:12:17
* 3E9BDA  KZR904   EHAM-UATG                                          2013/10/18 10:29:29
* 3E9BDA  METAL1   EHAM-UATG                                          2013/10/18 10:32:09
* 3EBD07  PACK2                                                       2013/10/18 06:22:12
   3F5B45                                                              2013/10/18 09:01:04
   3F5BF3  LM02                                                        2013/10/18 06:23:10
* 3F7A50  GAF715                                                      2013/10/18 08:46:20
   3F8CDE  TA57                                                        2013/10/18 10:00:06
* 3F8DD7  DLH7VC                                                      2013/10/18 06:27:04
* 3F8DD7  LM01                                                        2013/10/18 06:22:43
* 3F8DD7  LM01                                                        2013/10/18 06:27:30
   3FB450  GAFM70A                                                     2013/10/18 08:22:55
* 400AF5  EZY73VE  EGKK-EDDB                                          2013/10/18 17:46:15
* 440148                                                              2013/10/18 14:40:32
   473413  WZZ5RF   EPWA-EGPF                                          2013/10/18 21:56:29
   473413  WZZ5RF   EPWA-EGPF                                          2013/10/18 21:59:42
   473413  WZZ64R   EPWA-EGPF                                          2013/10/18 21:59:28
   473413  WZZ64R   EPWA-EGPF                                          2013/10/18 22:09:49
* 495231  CND518   LTBS-EHAM                                          2013/10/18 21:24:29
   4B1A58  EZS4633  EDDB-LFSB                                          2013/10/18 11:16:53
* 4CA70A  RYR1LG   EPWR-EGNX                                          2013/10/18 11:13:52
* 8007DE                                                              2013/10/18 14:51:19
* 88104F  HSDBO                                                       2013/10/18 09:45:55
* E80275  LAN9901                                                     2013/10/18 09:45
that's the way I'll be able to send my unknowns until christmas vacation...
regards Ingo
CYYZGUY
40" LED Monitor
40" LED Monitor
Jason,
AAL1119 KDEN-KBOS-KDEN
CYYZGUY
Hi Alan, a few more...
AWE404 No Route
AAL224 No Route
40" LED Monitor
40" LED Monitor
Jason,
AWE404 appears to be used on more than one route.  Today it is used for KPHL-KSFO but tomorrow it is used on KPHL-KPHX-KPHL
AAL224 KORD-KBOS-KORD
CYYZGUY
40" LED Monitor
40" LED Monitor
Hi Jason,
AAL1081 KORD-KBOS
CYYZGUY
Hi Alan
CPA094  No Route..
regards,
40" LED Monitor
40" LED Monitor
