Started by orkney, June 21, 2013, 02:28:12 PM
mikek
Hi Alan, do you also have access to update the airports table?
NZHB (Hobsonville) is still listed and appears on the map. It hasn't been an airfield for around 10+ years now and is pretty much on the way to being covered in houses.
Mike
CYYZGUY
#1471
Hi Alan...Goodmorning..
CKS248  No Route
BOX411 No Route
UAL1643 No Route
regards,
40" LED Monitor
40" LED Monitor
#1472
Hi Mike,
I can have it removed from the airports table but cannot remove it from the map as it is programmed into the software some where but I will add it to the list of things to be done.
CYYZGUY
#1473
Hi Alan
PIA784 No Route
VIR913P  No Route
regards,
40" LED Monitor
40" LED Monitor
Hi Jason,
PIA784 CYYZ-OPRN,OPKC
VIR913P I think is another positioning flight
CYYZGUY
#1475
Thanks alan, I posted a few at reply 1471 if you can take a look at those as well..
thank you as always..
Another one just came up...KLM48  No Route as well
UAL1734 No Route
PR118 No Route
CLX776 No Route
ACA033 No Route
40" LED Monitor
40" LED Monitor
Hi Jason,
I did the ones on 1471 apart from the one you added later but must have forgotten to reply to you.
CKS248 EDDP-KCVG
BOX411 KLAX-EDDF
UAL1643 KEWR-KDEN-KEWR
UAL1743 KAUS-KIAH
PAL118 is in the d/b under its icao code of PAL118 RPLL-CYVR-CYYZ
CLX776 ELLX-KHSV
ACA33 CYVR-YSSY
Hi Mike,
NZHB was removed from the server this morning.  If you download tomorrows database update it will be gone from the Navdata.
Aerotower
3DC826 - D-GWAW - PA34 - Piper PA34-200T Seneca II - Aeronautical Web Academy (http://www.awa.pt/site/?p=216)
Photo - http://www.jetphotos.net/viewphoto.php?id=7657514
Thanks Aerotower, entire fleet now in d/b.
flygfantast
Not populating: 683202, c/s TIE743V
Niklas
PS. Just downloaded the new beta version :D Looking good! DS.
Cable: Ecoflex-10 (10m+1m)
Evening Alan,
unknowns from RB V4 LOG:
   101010  GCHHI                                                       2013/10/20 07:30:10
* 3C4980  BER780   EDDH-EDDS                                          2013/10/20 11:35:57
   3C6611                                                              2013/10/20 15:30:26
   3D1075  DEEMF                                                       2013/10/20 12:12:11
   3D1474  DEFZO                                                       2013/10/20 14:50:53
   3D2B6F                                                              2013/10/20 08:51:40
   3D2DB3  DEPOD                                                       2013/10/20 11:53:38
* 3E7CBA  DKMKW                                                       2013/10/20 11:02:32
   3FEF83  DMXKL                                                       2013/10/20 11:37:55
   3FF295  0K                                                          2013/10/20 12:41:39
* 40072F                                                              2013/10/20 18:32:31
* 461E13  FCM822F  EDDF-EFHK                                          2013/10/20 10:15:05
* 473402  WZZ7MU   LHBP-EGGW                                          2013/10/20 12:11:03
* 473402  WZZ890   LHBP-EGGW                                          2013/10/20 12:33:43
   478385  SAS7792                                                     2013/10/20 12:54:11
* 4B18F7  SWR187J  EKCH-LSZH                                          2013/10/20 08:39:15
   4CA9CB  RYR8331  LICT-EKBI                                          2013/10/20 20:49:47
unknowns from RB V5 LOG:
* 101010  GCHHI                                                          2013/10/20 07:30:11
* 3C4E00        2013/10/20 15:41:18
* 3C60DC        2013/10/20 03:05:01
* 3D1075  DEEMF                                                          2013/10/20 12:12:07
* 3D1474  DEFZO                                                          2013/10/20 14:50:38
* 3D2B6F        2013/10/20 08:52:51
* 3D2DB3  DEPOD                                                          2013/10/20 11:53:22
* 3E7CBA  DKMKW                                                          2013/10/20 11:03:44
* 3FEF83  DMXKL                                                          2013/10/20 11:36:17
* 3FEF83        2013/10/20 14:40:52
* 3FF295  0K                                                             2013/10/20 12:41:13
* 3FF295  0K                                                             2013/10/20 16:01:45
* 408F6D        2013/10/20 00:18:14
* 445566        2013/10/20 08:42:16
* 445566        2013/10/20 14:44:55
* 445566        2013/10/20 18:01:01
* 445566        2013/10/20 22:34:40
* 451E9E        2013/10/20 13:21:51
* 484149  TRA1283                                                        2013/10/20 04:29:57
* 4A08E0        2013/10/20 11:09:25
* 4B0071        2013/10/20 11:27:12
* 4CA24B        2013/10/20 15:09:00
* 4CA642        2013/10/20 14:56:24
sorry, that I'm unable to inverstigate by myself, but it's likely impolsible to do it with an average internet speed of 180kBit/s...
Regards Ingo
No Worries Ingo, wil have a look at them and the ones from yesterday shortly
#1483
Hi Niklas,
683202 is unknown to me and has me confused.  Its a Kazak code but TIE is Time Air which is Czech?
flygfantast
Yes, that puzzled me too! Could be a miscode, only 17 msgs recevied. But I can't find any "similar" aircraft that would have miscoded in my log.
Niklas
