Started by orkney, June 21, 2013, 02:28:12 PM
Approaching Lands End on delivery as JBU6994 is AB4BA6 N827JB Airbus A320-232 c/n 5677 JetBlue Airways
Hi Alan
REA322M - EIDW-EGCC
REA323M - EGCC-EIDW
GreekSpy2001
Some more new ones for me
* 40067B                                                              2013/07/10 16:51:44
* 4006E7  MON683   LEAL-EGCC                                          2013/07/10 13:04:22
* 400B2F  EXS198Z  LEIB-EGNM                                          2013/07/10 14:09:03
* 30006E                                                              2013/07/11 08:04:43
   4008BB                                                              2013/07/11 13:01:01
* 43E7C1                                                              2013/07/11 12:21:19
* 4CA1D7                                                              2013/07/11 06:28:05
Graham
Graham,
40067B not allocated
4006E7 not allocated
400B2F not allocated
30006E decodes to I-FLRU which was a B462 now in Indonesia
4008BB not allocated
43E7C1 not allocated
4CA1D7 not allocated
Judwin45
Hi Alan
A78544 has just come up on 'myflights'
Keith
5 miles south of EGDY
Hi Keith,
A78544 decodes to N584FC which isnt assigned by the FAA so appears to be a miscode for which I have no tie up.
Judwin45
Thanks Alan, hope you don't mind me throwing these snippets at you.
N584FE was in the area at the same time, mode S A78546
Keith
Most probably it Keith either a miscode or a mangled fragment from it.
Forgot about this one advised by John Hargreaves
Out of XFW as EZY9001 was 40690D  G-EZWL  Airbus A320-214  c/n 5702  easyJet Airline
flygfantast
4AD721 SE-UYA, Schempp-Hirth Arcus M, c/n 38, Örebro Segelflygklubb (ex D-KUYA)
Niklas
Cable: Ecoflex-10 (10m+1m)
Xon
300575 I-XPRA G450 c/n 4279
#268
Afternoon Alan,
Just come on 'My Flights' :
Mode S only : E489E0
Flight ID : N11111
Flight Level : A steady 290ft !
Edit : Eventually climbed to 690ft before timing out.
I dont have anything on the hex Ian.  N11111 is a PA60 which is in the d/b under its allocated A0327F but the heights you detail would suggest a chopper of some kind.
