Started by orkney, June 21, 2013, 02:28:12 PM
Michel
QuoteCAO1034   =   AMS   -   PVG   -      ||   EHAM   -   ZSPD   -
Correct routing is EHAM-ZBTJ-ZSPD. Btw, could you update the routing of CAO1038 into EHAM-ZBTJ-ZSPD as well iso EHAM-ZBTJ?
Michel.
Hawkeye
Afternoon Alan,
Installed the latest update for which, once again I thank you and the team, but have found that out of the routes additions/amendments etc I submitted on July 15th, 35 have not been added, and only 15 have.
A 'sample check' of some of the ones John has sent in shows the same thing has happened there.
Could you explain why please?
Thanks,
Syd
I have not got a clue.  I have just had a look at my Navdata and the route shown there states the same as the server info I gave previously, what does yours detail?
Dana
4402A0,YR-SMU,PA-42-720 Cheyenne 3 , Has recently re registered as 1121 under same hex and same owner: SMURD
424242, AƩrospatiale AS 355F1 Ecureuil 2, Reg: YR-BBB
Hawkeye
Sorry Alan, but I don't understand what you are saying about routes shown and server info.  What would you like me to check in my Navdata?
Syd
Sorry Syd that answer was for CYYZGUY
For the answer to your question please see Reply 373 from yesterday
Dana, Can you advise what you mean "re registered as 1121"
CYYZGUY
Hi Alan, I am at work now.... 12:25 EDT, So I wont be home for a few more hours.  I guess I have the same question, what should I be checking to verify?  I have always kept up with the latest navdata updates, then I run the database explorer to make sure I have the correct # of aircraft showing.  Like I mentioned KLM695 had the wrong routes showing on my screen, but you say its been in the database since April, Maybe I am doing something wrong on my end....
Jason
40" LED Monitor
40" LED Monitor
shouriken
The Piper 4402A0 was registered as a civil aircraft (YR-SMU) and about 10 days ago got a military registration 1121.
112 is the emergency phone number in Romania.
SMURD means "Serviciul Mobil de Urgenta, Reanimare si Descarcerare", roughly translated in english as "Mobile Emergency Service for Resuscitation and Extrication". They have several helicopters and 1 airplane.
The SMURD units are operated by the Romanian Ministry of Interior and the Ministry of Health.
Here are some photos with their fleet: http://www.photoavia.net/photo?ia=2370
PS. Sorry for my english.
Liviu
Liviu
A.net JetPhotos.Net
RadarBox
John Racars
Thanks Michel, you are right and I correct this in my next report.
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
I dont know Jason why it would show that, both the Navdata and the server show that KLM695 routes EHAM-CYYZ and have attached a screenshot to show.
As you have the latest Navdata installed if you look up the route in d/b explorer it should show the same.  My only explanation is there was a crossed signal and the route from another aircraft was shown.  A look at your log may show if this was the case as you may possibly have the flight in there showing the correct and incorrect routing
#417
Got you now Liviu and many thanks for the explanation. You have no requirement to apologise for your English as it is much better than my Romanian  which is non existant :-))
Wish they would change the hex as well!
John Racars
Hi All,
KLM695 departed a copple of minutes ago from here. RadarBox24 showed the flight as EHAM-CYYZ on my screen.........
Kind Regards, John
13 NM East of EHAM
ANRB:
CYYZGUY
Thanks John Racars, I will check once I get home and will keep an eye out for it.....I will take a screenshot and post if it comes up incorrectly again....Maybe I have some old cached data?  Not too sure...
40" LED Monitor
40" LED Monitor
