Started by orkney, June 21, 2013, 02:28:12 PM
X
Picked these up from LHR before going LHR/CGN/IST on D-AGWO. I think 400F47 BEE351W was a double coder as it was also used by 400F43  BEE351W G-FBEB  E190  Flybe at 14:38:37
* 400899        2013/08/12 13:53:36
* 400F47  BEE351W                                                     2013/08/12 14:42:53
* 484176  KLM685   EHAM-MMMX                                 2013/08/12 14:29:44
X
I think they are all the same X either miscodes or decoding errors
Kenny
Ohh I didn't realized there is a new Navdata..  Thanks for pointing out that.
Kenny
Quote from: Runway 31 on August 12, 2013, 02:33:51 PM
Hi Kenny,
You are correct and the 2 aircraft you detail plus their newly delivered F50 have the operator as Hunnu Air in the Navdata published 05/08/2013.
The Airlines table was not however changed but has been now.
ANRB 3km north of VTBD
Kenny
Got new birds yesterday
* 005A14  MAGMA02                                                     2013/08/13 10:29:38
* 9C1044        2013/08/13 21:16:29
Michel
QuoteA new Transavia:
TRA5L LPPT-EHAM
Just discovered this one is flying EHAM-LPPT.
Some others:
TRA5A LPPT-EHAM
TRA11P LEIB-EHAM
TRA11T EHAM-LEIB
TRA15T LGSM-EHAM
TRA3A EHAM-LPFR
TRA3T LPFR-EHAM
CKK217 ZSPD-EHAM-LEZG
YZR7489 (ZSPD)-UNNN-EHAM-EDFH
Michel.
Hi Kenny,
Many thanks but I dont have any info on those 2 miscodes
Evening Alan,
Just had Tunisair TS-IMR A320-214 c/n 4344 come over. It is no longer miscoding it's hex as stated in d/b and is now correctly using 02A191.
Evening again Alan,
Just come on with mode S A05A0A which according to Airframes should be N1212C C441 c/n 441-0346.
However, it is showing a flight ID of EC-CGV and no further information apart from the American flag alongside the Mode S !
GreekSpy2001
some more from me
* 47837F                                                              2013/08/13 07:51:39
* 4B19EF                                                              2013/08/13 17:50:49
* 4CA24A                                                              2013/08/13 19:24:41
* A286B8  N262DB                                                      2013/08/13 10:42:39
* A286B8  N262DB                                                      2013/08/13 15:55:41
* 4CC275                                                              2013/08/14 07:37:29
* 4D20A0  9HCYL                                                       2013/08/14 11:28:30
Graham
#715
Hi Ian,
Thanks for the Tunisair info and another crazy one from you which I have difficulty in explaining but think I amy have the answer.
A05A0A N1212C Cessna 441 Conquest II 441-0346 Dodson International Parts given the owner its a wonder its still active and given this accident report I cannot see it being active http://aviation-safety.net/wikibase/wiki.php?id=144666  ouch!
My link doesnt appear to want to open up so the main bit of the report here
A Cessna 441 Conquest II, N1212C, (Dash 10 / Garrett TPE331-10 mod.), departed Muskegon County Airport - KMKG, Muskegon, Michigan, with the tow-bar still attached to the nose wheel of the aircraft. Upon realizing the situation with the tow-bar hitting the underside of the aircraft, the pilot diverted to W K Kellogg Airport - KBTL, Battle Creek, Michigan. The nose-gear with tow-bar still attached collapsed incurring substantial damage to the aircraft.
EC-CGV shows as Piper PA-28-180 Challenger c/n 28-7305583 but am unable to ascertain its history to see if it was N1212C in a previous life but it is looking like it is miscoding its previous ID but cannot confirm
Graham,
47837F  unknown to me
4B19EF decodes to HB-JVJ not assigned
4CA24A unknown to me
A286B8  N262DB Cirrus SR22 c/n 2915  DAB Aviation Inc Trustee
4CC275 unknown to me
4D20A0  9H-CYL Cessna T303 Crusader T30300005 Oasis Flight Malta
flygfantast
4AD64E SE-URN, Diamond HK36TTC, c/n 36.827, Torsby Flygklubb
7809D4 B-8202, Dassault Falcon 7X, c/n 159, Capital Airlines
Niklas
Cable: Ecoflex-10 (10m+1m)
X
Our unknown EP-TBD was in IST again this evening but could only see osram's so type still not confirmed
   735044  00000000                                                    2013/08/14 21:00:16
* AB1BBD  EM808                                                       2013/08/14 20:51:42
X
