Started by orkney, June 21, 2013, 02:28:12 PM
X
ABIBBD TC-*** Beech B300 King Air 350i c/n FL-808 ex N8148W
Xon
222222 YR-VLF PZ04 c/n ???
Used by several different aircrafts but maybe someone from Romania want to add this with reg.
X
#722
TC-OBY Onur Air was double coding earlier on OHY010
* 4BBC51  OHY010        2013/08/15 07:06:53
    4BBC59  OHY010   LTBA-LTAF       TC-OBY  A321  Onur Air             2013/08/15 07:05:56
Will be back in sandpit later today
X
Northern Watch
Good morning Alan
A few routes that did not populate yesterday although the JTG routes can be a bit dubious at times this is what they flew.
JTG782    LPPD - ENGM
JTG791    ENBR - LPPD  not ESSP - LTFE
ICE553    EDDM - BIKF
UAL953    EDDM - KORD
Keith
Morning Alan,
Time you were coming back here as you can see things are going a bit awry and needing your superior expertise to sort out !
With regard to EC-CGV. The Spanish register gives it as previously being registered as N9552N so that doesn't help the cause. Just to confuse things further, it also states that it has been in storage since September 2009 at Cuatro Vientos. It does however confirm it as PA-28-180 with c/n 28-7305583 so at least that looks right !
Ian,
Can you provide a link to the Spanish register please.
I noted EC-CGV here http://www.aire.org/rnac/preserved_eng.htm
Thanks again Keith,
Unfortunately charter routes and their ID's can be very short lived before they move onto a diferent route being used with the same flight ID.
In airports table, EGPA, Kirkwall is on the Orkney Islands (not Shetland).
#729
Will amend the info, Thanks
Here you go Alan. Ignore the fact that it states it hasn't been updated since June 2010. I've entered queries into the database and usually been provided with up to date answers.
http://www.aire.org/rnac/index_eng.htm
Having checked it out, it appears to be the same one that you are using !
You can also try this which comes in pdf format but does not include much in the way of information on each individual aircraft and takes for ever as you cannot 'home into' a particular aircraft but have to scroll through the whole register. It is, however, up to date :
http://www.seguridadaerea.gob.es/media/3748914/aeronaves_inscritas.pdf
And finally, there is this :
http://www.brugier.com/n_ec.htm
Take your pick (as Michael Miles would say).
Many thanks Ian.
For info you can search for a particular aircraft on http://www.seguridadaerea.gob.es/media/3748914/aeronaves_inscritas.pdf
Use Edit/Find
Who is Michael Miles BTW, remember you are more ancient than me!!
shouriken
Quote222222 YR-VLF PZ04 c/n ???
The Romanian Airclub's PZL-Mielec 104 Wilga 35A YR-VLP cn 139503 is not active in the Romanian register since march 2012.
Even in Romania, there are several aircraft with 222222: YR-VIS (PZL-Mielec 104 Wilga 35A, cn 118382) and YR-5108 (Flight Design CTSW, cn 07-03-26)
Liviu
A.net JetPhotos.Net
RadarBox
flygfantast
Not populating:
42429F c/s 00000000 VP-BIF??
4242D4 c/s FLYHERE
Niklas
Cable: Ecoflex-10 (10m+1m)
