Database Update Requests
Started by orkney, June 21, 2013, 02:28:12 PM
I am starting off on my journey to Spain first thing in the morning and will be off line until Sunday evening,  Andrew (Orkney) will be looking after your every need in the meantime.
EK01
Andrew,
B737-476 c/n 24438 of Samair with Hex of 505C24 is coming uo in the d/b as registration OM-SBA. It should be OM-SDA according to Airframes.
orkney
Hello Ian
That one is now fixed.
Thank you
Andrew
superspotter
Lagos calling again;
I have just spotted a wee mistake in the aircraft listing, Hexcode 064125 which is an AW139 of Caverton Helicopters is showing as a Boeing 734??
regards clive.
My equipment: Airnav mobile antenna stuck outside of the highest hotel window available!
View my pictures at  http://www.flickr.com/photos/superspotter
orkney
Hello Clive
That is strange, are you using a recent navdata,  it has been in correctly as the helicopter since at least 30th october 2012.
Thank you
Andrew
superspotter
Yes the last one that was updated earlier this month. Maybe just a glitch, I will check next time it appears.
regards clive.
EK01
flygfantast
Alan/Andrew
The mystery 42429F VP-BIF on radar today using RLU8404 (RusLine).
Also VP-BVD (hex & c/n unknown) CRJ-100 left ARN enroute to VOG as RLU8302 this night destined for Rusline, it was all white, so probably none of the ex Delta aircraft.
Hopefully someone can shed some light on these aircraft identities.
Niklas
Antenna: External WiMo GP-1090 (~10m over the ground)
Pre-amplifier: AS-1090 with AS-1090BT
Cable: Ecoflex-10 (10m+1m)
Nearest airports: 50km from ESSL & ESCF (military)
My photos: http://www.flickr.com/photos/flygfantast/
orkney
Hello Niklas
Sadly I cannot find anything about your ones.
Thank you
Andrew
Mark Coles
just to confuse the issue, there's a photo here http://www.flickr.com/photos/bycac/9520011882/ of VP-BVD a NordStar ATR-42-600 at TLS on the 14th
Mark
daily or weekly updates for your database
www.dbpop.co.uk
Skyliner
VP-BVD is msn 7440 acc the Arlanda locals, another one for RusLine
Cheers, Chris
Quote from: flygfantast on August 23, 2013, 09:13:41 PM
Alan/Andrew
Niklas
Hi Niklas,
CRJ c/n 7440 is ex N408CA which has been at Arlanda since mid May I believe.
X
On network
E48E92 GOL1317
x
X
Alan/Andrew
New Azerbaijan code climbing from f/l 270 to 300
* 60087C                                                              2013/08/25 03:05:54
X
viasa
Quote from: Mark Coles on August 24, 2013, 12:45:49 PM
Mark
This is msn 1002 - the first ATR42-600 for NordStar.
