Author Topic: No hardware connected  (Read 2465 times)
airman
« on: August 10, 2013, 02:59:58 PM »
As my airnavradar was working in windows7 on an old PC, I am trying to install it on a new one with Win8 64b. The soft is correctly installed by no connection to the hardware (red flag on the bottom red window) I tried to set the drivers throught the ANRB65bitDrivers, but unsuccefully. I try through the config panel also unsuccefully  (drivers not correct).
What I have to do?
Re: No hardware connected
« Reply #1 on: August 10, 2013, 05:03:34 PM »
airman
« Reply #2 on: August 10, 2013, 05:42:28 PM »
Thanks for your reply
Now I did it, but the problem is for each start, I have to do again in order to bypass the uncorrect driver under win8. It seems very uncomfortable and tricky.
Any solution about this curious driver
« Reply #3 on: August 10, 2013, 07:23:40 PM »
Normally once you get it up an running there is no further problems as far as I am aware.  Once the driver is installed there shouldnt be any problem.
I dont use Windows 8 myself and my only experience of it was from a forum member who lived nearby who had the same problem but once i got the driver installed he has had no problems.
You may get futher assiatance from contacting [email protected]
airman
« Reply #4 on: August 10, 2013, 08:04:24 PM »
Thanks for your information. I will send a message to support because I needs to reset the option after each start!Thanks. Have a good night
