New Navdata.db3 - 20130819
Started by orkney, August 20, 2013, 09:33:16 AM
orkney
Hello
Once again, The new Navdata Installer can be downloaded from the link below:
http://www.airnavsystems.com/download/ANRB/DBUpdater/ANRBDBUpdater20130819.exe
This one has  203,651 aircraft records.
Thank you
Andrew
Kenny
Download and installed without any problem.
ANRB 3km north of VTBD
I've lost 2! Showing 203,649 - many thanks to all updaters who are the only people doing anything to keep RB going, such a shame that AN can't or unwilling to match your enthusiasm for their product.   Thanks Guys!!!
vena
User since 2/2010 ARNB 4.03, Nejdek CZ, 18km NW LKKV, WIN7 32Bit Professional
Antenna:external Rama , 15m Ecoflex cable,
nortonbeak
Northern Watch
Thank you once again and please keep up the good excellent work.
regards
Keith
jim_stockwell
Thank you all for continuing this great work. Really does make a difference! (Like CoastguardJohn I seem to have lost 2 as I have 203649)
Jim
54901 - Jim
KOSH - Oshkosh, Wisconsin USA
Maybe I had populated another couple when looking at the total for checking, the total is round about what it states in the opening reply.  Nothing stays the same long in d/b land.
Are you aware that you're using the wrong date/timestamp format on the routes table?
The field is defined as varchar(14), so using the format DDMMYYYY HH:MM:SS doesn't even match the size I defined for that field.
Routes downloaded online from the server have the correct format (YYYYMMDDHHMMSS):
Suggest you fix this to ensure that the route expiry routines in ANRB work correctly.
orkney
Hello Tarbat
We do not do anything with the timestamp. The format of the timestamp is decided by airnav's database settings. We cannot change it.
Andrew
#11
In that case AirNav need to fix this.  Added to bug-tracking #135.
Fortunately I use an empty Navdata database and simply rely on real-time updates from the servers, so doesn't affect me.
MIKE.UTD
A big thank you again from me !!!
Mike.
shouriken
It looks like the new navdata database lost a lot of entries from the airlines table.
Now it contains only 1 entry. The 20130805 version contained 4985 entries.
The size of the 20130805 was 51.755.008 bytes and the size of 20130819 is 51.537.920 bytes.
PS. It's a little bit strange that the sqlite driver does not complain about the size of the data inserted in the timestamp field of the routes table.
Liviu
A.net JetPhotos.Net
RadarBox
Liviu,
I just checked the table that is used for the airlines and everything is there as it should be so it looks like the compiler must have had a problem.  I will ensure that it is OK next week when I run it again.  I have always wondered, is the airlines table actually used for anything?
