New Navdata.db3 - 20131013
Started by orkney, October 13, 2013, 10:03:56 PM
orkney
Hello
Once again, The new Navdata Installer can be downloaded from the link below:
http://www.airnavsystems.com/download/ANRB/DBUpdater/ANRBDBUpdater20131013.exe
This one has 206,855 aircraft records.
Thank you
Andrew
nortonbeak
You all do such a great job:-)
Well done!
jim_stockwell
Thank you Andrew
Update worked like a dream!
Jim
CYYZGUY
Hey guys, I get 206,854
1 off is not too bad!
Thanks again!
Jason
40" LED Monitor
40" LED Monitor
Northern Watch
Thank you once again for all your hard work.  Not much use to me at the moment as my box is still away being repaired. I also got 205,854.
Keith
Its taking a while Keith, thought you would have had it back by now.
MIKE.UTD
Fantastic work yet again.
Thanks for all your efforts.
Mike.
Northern Watch
Hi Alan
I was told it is due to a heavy amount of repair work at the moment.  Hopefully, I should hear what the damage is and the approximate cost this week.  It would happen when I am away from home for a while and staying not far from EFPH again which has far better overhead traffic.
Keith
Kenny
ANRB 3km north of VTBD
If you're running the v5 beta, preferably don't download this navdata.db3 update, but instead use the Database Updater in Radarbox itself.  It's more up-to-date.
Click on MENU - FILE - DATABASE EXPLORER, then click on the DATABASE UPDATES tab and follow the instructions.
PAULWIGGY
Is there any issue with the webpage at present?
HTTP Error 404.0 - Not Found
The resource you are looking for has been removed, had its name changed, or is temporarily unavailable.I have tried to download the latest update and get this error
Hi Paul,
Please see http://www.airnavsystems.com/forum/index.php?topic=7914.0  Version5 is now available and the updates are now done from within the application and the previous Navadata updates are no longer
available.
Once you have upgraded to V5 there have been a couple of further updates and we are now at V5.00.53 http://www.airnavsystems.com/forum/index.php?topic=7931.msg97798#msg97798 which should be updated after the V5 update above
It should run smoothly but if you need any assistance drop me an email
PAULWIGGY
Thanks Alan
appears to have updated accordingly 208000 plus.
problems noted are
no old log information stored anymore
when viewing my report/log it then states not responding and gets stuck there and you cannot close it down using the arrow on the top right.
Brgds
 Sorry Paul I forgot to tell you to save your mylog.  Have you updated to the latest version V5.00.53 Paul.  There is a fix for your mylog/reporter issue which will be in the next release,
PAULWIGGY
Thanks Alan
I thought I had updated to .53 but have now.
if ive lost my log data, its not the end of the world.
thanks for your assistance in setting me up
brgds Paul
