New AirNav RadarBox 5.00 Beta Software Released and Avaiable for Download
Started by AirNav Development, October 19, 2013, 06:04:00 AM
We are happy to announce the release of the brand new "AirNav RadarBox 5.00 Beta" software.
It's a new version of our Windows software with all reported bugs corrected and with some new features. It has been on test for a few weeks and it is now time to release it, still in Beta mode, to our forum.
Our development team and our team of beta testers will be present on this thread.
At this point we are looking for more problems to be reported and corrected. This version intends to be mainly a correction of all reported problems and once released in non-beta mode we will start working on important new features.
* We would like to give a special thank you message to our dedicated beta testing team who has put hours of work on this job and of course to all the AirNav Systems team that dedicated the last few months working on this task. *
Download links:
Full installation:
http://www.airnavsystems.com/download/ANRB/ANRB50044BetaSetup.exe
Upgrade from V4.03:
http://www.airnavsystems.com/download/ANRB/ANRBUpgrade403to50044.exe
Windows 8 drivers quick note: we are still working on the Windows 8 drivers problem which we hope to have corrected in 10-15 days (we are waiting for Microsoft certification of the new drivers).
List of corrected bugs:
Aircraft not timing out
Mangled type designator
Local alerts not working properly
Equatorial Black Hole bug
Preference box re-sizing
Diacritical mark bug
Sort network flight by distance
The Spurious Position Bug
Aircraft Sessions Extended
Maps unreliable
The Aircraft in Limbo bug
Automatic Software Update Feature
3D height problem - FT vs Meters
Problems with 3D - localhost vs 127.0.0.1
Administration Rights Problems on certain machines
Setup for both Upgrade and New Installations
POST Problems with Apache (email sending feature)
Flights in the Navdata and on the server showing only -
Routes not showing as via
Photo thumbnails of aircraft not showing in mylog
Database updater giving error when operated
Wrong date/time stamp on routes table
Photo missing in 3D view aircraft information box
No Squawk Codes being displayed
Some Flight IDs not being displayed
Satellite and OpenStreetMap Downloads not working
Change installation folders
Memory Leak on Data Updater
Map doesn't show all labels from tracked flights
Error when selecting Add Record in Database Explorer
Refinement to filtering of corrupted FlightIDs and Squawks
3D models and trails missing when playing a recording
High CPU Usage - database updates
Saving map colour changes
Double clicking on a network flight problems
Aircraft displayed behind trails
Network flights not showing route data on certain conditions
SmartView showing network aircraft with no position
Transition from MyFlights to Network - frozen aircraft
Network trail lines not timing out
Aircraft silhouettes missing in certain conditions
Database explorer error when changing search field
Provide ability to scroll across the Quick Filter Toolbar
Altitude missing on aircraft in MyFlights
Airline logo column too small on grid view
Receive photos and aircraft and flight data from server
Error message when sending MyLog by email
Manually added photo not appearing in MyLog
MyFlights aircraft listed in Network tab
Alert Box problems
Add CO field to Grid Visible Columns
Add maximize and restore controls to Database Explorer
Allow users to disable auto sort on main grid view
New features:
Sending emails by custom server
Encrypt navdata.db3 file
All comms to/from server encrypted
Users who don't share flight data or are not subscribed to the network will not received flight (photo/route information from server
A couple of new features to be aware of:
1. Preferences - Radarbox - Callsign and Squawk Validation - Tick the box to filter out garbled FlightIDs and Squawks, at the expense of requiring 2 consecutive identical messages for FlightIDs and Squawks.
2. Database Explorer has a new Database Updates tab.
Any questions, just ask.  There are quite a few other improvements that you'll probably discover along the way!
shouriken
Will the upgrade403to50044.exe work to upgrade from 3.13?
As far as I remember, the difference between 3.13 and 4.03 was the 3D feature.
Liviu
A.net JetPhotos.Net
RadarBox
Sorry, not tested upgrade from 3.13, as I didn't have a 3.13 install to test from.
I dont see any reason why it should not, the only difference is 3D.  If you dont subsscribe to 3D you will get 2D only.
The upgrade will look for your ANRB.exe.  If you have installed to a different path than that detailed by the installer you will require to direct it to the exe.
shouriken
I did the upgrade with 403 updater and ANRB complained about anrb.dat not found.
Installed 403 on another machine, copied the anrb.dat from it and now the 500beta works.
Liviu
A.net JetPhotos.Net
RadarBox
Liviu, good to know there's a way to upgrade from 3.13.  But note the warnings, this is NOT an official upgrade route, has not been tested, and may give problems if you try to use 3D.
shouriken
Note that if someone takes this path to upgrade from 313 and then decides to subscribe for the 3D, 500 will not work because there will be missing the GE_Models and GE_Layers folders and maybe some other files.
Liviu
A.net JetPhotos.Net
RadarBox
Marpleman
Well done to all involved. Let's hope the testing goes well.
I must admit, I'm baffled as to why those not sharing flight data or subscribe to the network, not receiving updates from the server,can be classed as a "feature" of the release?
Your definition of "feature" needs looking at closely.
Just an observation - now that the Navdata database in encrypted, the NavData Editing Tool is now unusable, which is a shame.
Quote from: RodJust an observation - now that the Navdata database in encrypted, the NavData Editing Tool is now unusable, which is a shame.
Indeed!
Tried to launch 3D with old GE plugin. Result: Plugin crashed. While (re-)installing newest version: ANRB disappeared from tasklist. Maybe crashed maybe shuted down without notification. As far as I noticed no damages to the database files have occurde. so far so good.
Quote from: airnav systemsUsers who don't share flight data and not subscribed to the network will not received flight (photo/route information from server
I have two boxes, one with active network subscription and one without. Both are alway on with sharing "ON". Does this mean, that only the box with active Network subscription gets updates or is it sufficient if only one have an active subscription. One of the boxes is running -with some short outtages- 24/7 since 1st of December 2009 -this are about 34000h of shared data. But if I have to pay for two network subscriptions to get updates for both boxes I've to say googbye...
Just had a problem/almost crash with new version. If you want I can send you the "crash report" as text file.
Finally... Many thanks for finally launching the new long awaited version of RB software.
Regards Ingo
To clarify if you share or pay for the network subscription you will get route and aircraft data.
I will arrange for the the line to be changed to read as follows
