Database updates
Started by dunc8543, October 23, 2013, 09:20:17 AM
dunc8543
Hi all,
Why is it that aircraft that are manually updated and added to the database yesterday are not even in the database today.
The database is set to not overwrite manually changed records.
Dunc
The only thing I can suggest that they were not saved correctly.  If you have added something to your local Navdata and we dont have it in the database and you have got it marked to ignore manually changed records I cannot see that an update can change what it doesnt have details on.
dunc8543
Thanks for the reply.
I think I may have the answer, I have just updated a record today and didn't see the that right at the end of the record is a box "Autoupdate Y/No".
I have altered this to no and will check tomorrow.
Dunc
That will be the reason Dunc
dunc8543
Tried to update the database but with a N in the Autoupdate but this has still been overwritten and all my entries amended.
Can you please enlighten me on the correct proceedure so that it can be resolved as there is either a glitch in the programme or its my ineptness.
Thanks Dunc
Dunc,
On the database updater there is also a tick box for Do Not Update Manually Changed Records, the N only tells the system that this is a manually changed record.
An alternative is to pass me the datails of the aircraft that I dont have in the database and I can have them included but if you dont want to share them no worries
dunc8543
Yep seen that and amended the Y to N makes no difference.
Database not set to update records automatically yet still will not save any amendments you make.
Dunc, this has definitely been tested, and as long as AUTOUPDATE on the aircraft record is "N", it never gets updated.  Maybe you can describe exactly what you're doing, so we can understand what might be going wrong.
Dunc,
Once you have made your entry and changed Y to N did you click somewhere on the grid to set the N entry?
dunc8543
Hi Tarbat,
Preferences- Radarbox- Auto populate aircraft data -OFF (Unticked) , Auto update manually changed records- OFF  (Unticked)
Database explorer- Do not update manually changed records- selected
Aircraft Details amended and in the last box AUTOUPDATE- N
Click in another box to confirm entry
Database explorer then closed but as soon as Radarbox closes and then opened again all details revert back to original details
Dunc
dunc8543
Hi Tarbat,
These 2 ?
Dunc
dunc8543
Thanks will give it a try
Dunc
dunc8543
Hi Guys,
Sorry to be a pain but any updates I make are still not saved in the database after I log off and then back in.
If I wanted to make the following detail changes can you please give me a step by step guide on how to do it.
eg. AE071C is a USAF F-15
If I wanted to record it in database as follows
AT= F-15 /  AN= McDonnell Douglas F-15 Eagle / AC= USAF- RAF Lakenheath, Suffolk
What would be the correct proceedure and settings
Thanks in anticipation
Dunc
