New AirNav RadarBox 5.00.52 Beta Upgrade
Started by AirNav Development, October 30, 2013, 11:09:29 AM
If you want to keep ALL the old photos, then turn Autopopulate off in preferences and don't download a new database.
#16
For this example I've set "Screen refresh rate" to 10000ms.  Set it to 100ms for a more frequent output to port 30003.
Sending log with own mail account works for only one recipient (as in 047).Not sure AirNav have ever claimed it will work with multiple recipients.  I certainly never tested that.
Using a yahoo account to send log to yahoo groups (registered with the same account) does not work (as in 047).Sorry, I can't help, I only have BT and Gmail email accounts.
vonsmalhausen
Tarbat, that is just my problem : I don't want the OLD photos, I want my NEW, the program keeps feeding me with old, outdated ones
would'nd it be that much simpler to have that autoupdate switch set to "N", or at least give us the possibility to work in the DB our self by selecting/altering whole columns, instead of selecting/editing each and every cell as we have to do it now ?
#18
Obviously ANRB has no way of knowing if you want to keep the photo you've already got, or download the latest one from the server, other than using the AUTOUPDATE = N flag.  If the photos being delivered by the server are wrong or out of date, then you can notify the Database Update team for correction.
To remind everyone, the reason for changing the format of photo thumbnails is to cope with multiple aircraft with the same Registration - such as those so that share  the "01" registration for example.
#19
I already asked previously for that info and received no reply.  Even the latest one from Airliners would not be good enough.  I have been looking at Germanwings and at least two of them have the old clour scheme as the newest with the new scheme second.
vonsmalhausen
I feel like turning around in circles, if AirNav wants to change the way thumbnails are showed, that's fine for me, but please do not encrypt the DB so we still can work on it to alter the data in a program like  NavData.db3 Editing Tool.
oh, and as much for the multiple aircraft with the same registration, earlier this evening deleted a D- registred B727 that had populated for a "new" reg ( don't ask me wich one, I deleted it right away )
anyway, i'll be getting back to V4 and live with it as long as it is possible for my "work in the field", for the more serious work at home, i'm already looking out for a SBS
#21
Ever helpful.  Some are busting a gut to make this a better product for us all and all we ask is a little help to point out errors or discrepancies which fortunately some are happy to do.  Advising which airlines could do with freshening the photos is easy enough and i have went through the Germanwings fleet and ensure they all now show their new colours.
vonsmalhausen, I've offered you help and advice on this matter.  There's little more I can suggest.  I'm just an unpaid beta testing trying to improve Radarbox.  I posted several days ago what changes were being made with photo retrieval, and asked for feedback.  If, as you say, you've got 100,000 aircraft that you want to stop photos downloading, then you're probably better off turning Autopopulate off, and ensure all the PTTN & PTTN2 fields are blank.
CYYZGUY
I can say the most recent patch installed for me without any problems at all..
The radar rings are now appearing over water as well.
Thanks alot for the hard work Airnav and Testers.
regards,
40" LED Monitor
40" LED Monitor
prbflight
All working good here too with the latest version so far.
Is there a fix coming for the MyLog window position and size not being saved on close?  Minor bug but annoying.
Great job and kudos to all that have been working on this new release.
Paul@cyyb
mikek
I've had a try again now I'm home and the problem still exists not allowing me to run the .52 beta as it think my computer is set to after the 30th of November.
Also had a look and not sure where I can change any setting that might affect it (other than manually changing the date which I don't want to do...)
Mike
shouriken
When restarting 052 this morning I've got "This is a beta version not allowed to run after Nov 30th 2013. Check for non-beta version online. Application will now close"
Tried to change regional settings to UK, but still not starting.
Date/time is synchronized with ntp.
Liviu
A.net JetPhotos.Net
RadarBox
mikek
Phew (kind of..), I'm not the only one. I guess it's just that NZ is so far ahead of the rest of the world I get to find these things out first ;)!
Starburstdave
Hi all
Just switched on my computer to start Radarbox and I have also got the message "This is a beta version not allowed to run after Nov 30th 2013. Check for non-beta version online. Application will now close". I installed the upgrade yesterday without any problems and ran the program all day without problems. All settings for clock are correct and and date format set for UK.
Dave
A fix for the beta expiry problem is in progress.
