New AirNav RadarBox 5.00.52 Beta Upgrade
Started by AirNav Development, October 30, 2013, 11:09:29 AM
As you know AirNav RadarBox 5 is still in beta mode which means we are intensively getting user feedback, testing and implementing corrections to all reported problems.
LIST OF PROBLEMS FIXED:
238 Radar rings disappear over water
239 2D map view not working
242 Log and alert sending by using own mail account is not..
249 Wrong photo downloaded
250 Aircraft registration and type missing on MyFlights
251 Port 30003 Issue
257 High CPU usage in MyLog
258 Report Refinement to photo thumbnail display
259 Show only fleet watch flights on map not working
261 3D Activation problems
262 Navdata Update File to be Encrypted
REMAIN TO BE CORRECTED
184 Bug Report Windows 8 Drivers
236 Feature Request Menu "Report Aircraft Record Error to Database Updater ...
237 Bug Report MyLog Report shows all flights as NEW
243 Bug Report Some new airports not showing label on map
244 Bug Report erroneous altitude reported after timeout
246 Bug Report Computer crashes with Office 2010 installed
263 Bug Report User with serious 3D issues after V5 was released
264 Bug Report Route with leading zero not showing
265 Bug Report Still being able to access navdata.db3 from external ap...
Upgrade (need to have any v5  installed):
(The download has a bug which will not let you run after the 30th, this is being fixed and a new release will be put up soon)
http://www.airnavsystems.com/download/ANRB/ANRBUpgradeto50052.exe
#1
Add these to the REMAIN TO BE CORRECTED list.
267   Bug Report   PZP in FlightID
268   Bug Report   ID & AIR messages missing from port 30003 output
Kenny
Downloaded and found that
MyLog seems to be more responsive now.
the bug
seems to fix itself.  Now I see just some of the flights have * in both yesterday and today report.
* 7043E2  319                                                            2013/10/29 11:57:02
   880009        2013/10/29 12:48:04
   880422  6102                                                           2013/10/29 01:10:30
   880422  6102                                                           2013/10/29 15:36:55
* 8805A5  RCB697                                                         2013/10/29 11:25:42
ANRB 3km north of VTBD
Quote from: Kenny237 Bug Report MyLog Report shows all flights as NEW
It is partially, but not completely fixed, which is why the beta testers haven't yet signed this one off - but it's nearly there.
mikek
I'm getting a problem with the new Beta.
It installs fine, but when I try and open it, it gets to the 'Loading Framework' stage and then comes up with this alert:
'This is a beta version not allowed to run after Nov 30th 2013. Check for non-beta version online. Application will now close'.
My computer date is set to the correct date and I don't see why it every would have not been.
I can reinstall .0047 again and it all runs fine.
Any ideas?
Mike
#5
Mike, what country are you in?  What date format does your PC use?  I've reported this as a possible urgent problem to the Airnav Dev team.
mikek
I'm in New Zealand. I'm not quite sure what you mean by the date format, but I've just arrived at work and won't be able to check for around another 8 or 9 hours when I'm done for the day...
Mike
vonsmalhausen
hoped for a solution for the picture download in this release, ... nope, still get these new style pic formats, even for pics that are already in the folder.
oh well, maybe next time
#8
Can you give an example.  What do you mean by "new style pic formats".  I didn't think the format of pictures had changed.  Remember, if you want to stop pictures being downloaded, mark the aircraft with AUTOUPDATE = N in Navdata aircraft table.
Also see http://www.airnavsystems.com/forum/index.php?topic=7919.msg97522#msg97522
shouriken
Updated the database after installing 052 and I don't see high CPU usage and delays when browsing through MyLog/Grids.
What exactly does "251 Port 30003 Issue" fixed means?
I've logged the port 30003 for a few minutes and it still output messages every "Screen refresh rate".
Ex.:
MSG,6,0,0,504DE2,0,2013.10.30,20:46:00.532,2013.10.30,20:46:00.532,,33000,,,,,,6117,0,0,0,0
MSG,5,0,0,504DE2,0,2013.10.30,20:46:10.564,2013.10.30,20:46:10.564,,33000,,,,,,,,,,
MSG,6,0,0,504DE2,0,2013.10.30,20:46:10.564,2013.10.30,20:46:10.564,,33000,,,,,,,0,0,0,0
MSG,4,0,0,ABDE34,0,2013.10.30,20:46:20.595,2013.10.30,20:46:20.595,,,501.7,119.9,,,0,,,,,
MSG,6,0,0,ABDE34,0,2013.10.30,20:46:20.611,2013.10.30,20:46:20.611,,35000,,,,,,3473,0,0,0,0
MSG,4,0,0,ABDE34,0,2013.10.30,20:46:30.642,2013.10.30,20:46:30.642,,,501.7,119.9,,,0,,,,,
For this example I've set "Screen refresh rate" to 10000ms.
"242 Log and alert sending by using own mail account is not.."
Sending log with own mail account works for only one recipient (as in 047).
Using a yahoo account to send log to yahoo groups (registered with the same account) does not work (as in 047).
Sending log using AirNav mail server is still truncated.
Sending log using own mail account is not truncated (as in 047).
Liviu
A.net JetPhotos.Net
RadarBox
vonsmalhausen
something like this
So, for the ones where you want it to use the old photo, have you marked  the aircraft in Navdata with AUTOUPDATE = N ?  That's the only way ANRB knows not to download the latest photo.
vonsmalhausen
getting a new picture is not the end of the world, but if the "new" picture is one of the plane in the old cs of that company, or before a newly applied sticker ; it causes troubles for what i'm using my RB for : go spotting aircraft at airfields !
ok, the examples I used do not show this ( I just painfully had purged my pic folder from all these errors, GermanWings, Hop! and JetAir, just to mention a couple of them ) but it takes not long to get them back
vonsmalhausen
do you sincerely mean I have to change EVERY entry in the DB to "N" to get rid of this ??????????????????
do you know how painful it is to change just one entry in that poor of a excuse "database explorer" ??!!!
and I would have to do this for over 100.000 or what is it entry's, ..... really ??????
vonsmalhausen
it even gets better ; now i'm not getting any pictures at all
