New AirNav RadarBox 5.00.53 Beta Upgrade
Started by AirNav Development, November 01, 2013, 09:20:28 AM
shouriken
I had the unfortunate idea to stop/start anrb.exe today.
When restarting, I got the message "beta version cannot run after 30 November".
It looks like a new beta is necessary :)
Liviu
A.net JetPhotos.Net
RadarBox
Starburstdave
Started up Radarbox this morning and I have got the message about the software not being able to run after 30th November due to it being a beta version. I thought this had been fixed after last month. Hope there's a fix soon.
Dave
vena
I have the same problem, I had to go back to 5.00.047 :-(
Vena
User since 2/2010 ARNB 4.03, Nejdek CZ, 18km NW LKKV, WIN7 32Bit Professional
Antenna:external Rama , 15m Ecoflex cable,
shouriken
I've changed the date to 29 November, ANRB was happy with that, reverted back to the real date.
Liviu
A.net JetPhotos.Net
RadarBox
Undertaker
I have the same 30th November 2013 problem how do we get it right ?
Tony
FACTflights
Got the same problem here.   Unfortunately the date change fix won't work with me.  I've other programmes running that are date sensitive.
John
ZS1AGH
No HF antennae at the moment.
nortonbeak
Same here. Can't use the date reset workaround.:-(
A new beta version will be posted shortly.
Hopefully earlier than Sunday morning 8:00 UTC...
FACTflights
A big thank you to support.  Now running version 5.00.062.  Problem solved.
John
ZS1AGH
Kenny
Quote from: Runway 31 on November 30, 2013, 09:02:40 AM
Hopefully it will release soon.   In the mean time Bangkok Thailand will be offline.
Kenny
ANRB 3km north of VTBD
Kenny
I will be out for the afternoon and until Dev is available to post a thread to the forum with the new beta, you can download it here http://www.airnavsystems.com/download/ANRB/ANRBUpgradeto50062.exe
