New AirNav RadarBox 5.00.53 Beta Upgrade
Started by AirNav Development, November 01, 2013, 09:20:28 AM
v53 is out.
Corrected:
- Version 5.00.53 corrects the bug which prevented the RB software running after 30th October
Download link:
http://www.airnavsystems.com/download/ANRB/ANRBUpgradeto50053.exe
Just to confirm, this v5.00.053 fixes the 30th November bug.  Also, the MyLog TODAY & YESTERDAY reports should now be reporting new aircraft with an "*" correctly.
jim_stockwell
Good morning all
I can't believe that I am the first to upgrade and comment!
All things seem to be fine with a manual restart after a database update which shows 208013 aircraft.
My log has aircraft being recorded and added to the listing of previous recordings. Yet to see anything new, so don't know if * will be seen.
Thanks to all for getting v52 sorted
Jim
lambertw
Just installed the new upgrade from 5.00.044 to 5.0053 and lost all the 3D features from 5.00.044 or was the 5.00.044 3D features a mistake.
lambertw, did you have 3D in v4 - i.e. did you pay for 3D?  If you did, then contact Airnav support to get 3D re-enabled.
lambertw
In that case you unfortunately had a little taster of 3D in v44, which was cruelly snatched away from you ;)
lambertw
Reverted back to 5.00.044 and got 3D google earth view ect but with no aircraft models anymore.
lambertw
Just looked at 3D view again and now have Models as well,wots going on ?.
Is that with v5.00.053?  If not, maybe start a new thread for this.
lambertw
Kenny
Downloaded and installed without problem.  Nice to see quick turn around.
Kenny
ANRB 3km north of VTBD
Since chanching to .053 from .047 it's nearly impossible for me to get the Window spread over two monitors. Switching between maximized Window and Window results in errors, too. Chanching window size: Error message. But the software seems to stay operational. No error messages if menus were opened or settings were changed.
Going to Photo section of MyLog: starts loading, stopps after a few seconds and ANRB Software freezes with continously consuming 25% of CPU load. Let it there for a couple of minutes without coming back. Tried to shut-down Software. No reaction. Had to take the crowbar and kill the ANRB.exe in taskmanager.
wxwarn
Just loaded 5.00.053 and found a few issues:
- Myflights count does not match the number of planes on screen
- Planes that are in my antenna range are showing a O next to the flight and should be shown.
