New AirNav RadarBox 5.00.53 Beta Upgrade
Started by AirNav Development, November 01, 2013, 09:20:28 AM
cosmefulanito
where I can find the number of aircraft in the database??
tommyg
Tarbat.
Yes, autopopulate is ticked in my preferences.
With the new database populate in V5, is there going to be someway that we can all check what the current database load is?
tommyg
Tommyg
Cosmefulanito,
You can find how many aircraft you have in the database by looking up File/Database Explorer/Tables/Aircraft and when it opens up you see ****** rows loaded in **ms.  That tells you how many.
Quote from: tommygWith the new database populate in V5, is there going to be someway that we can all check what the current database load is?
My understand is that there is a new database available every day in the v5 Database Update facility.  So, if you really want to, you can download a new one every day with the latest updates.  For myself, I never bother with that, and just let Autopopulate work in the background.
mikek
My Log seems to be working fine now when clicking on something that doesn't have a photo.
Reporter also seems to be indicating correctly for new aircraft. I do see the point made earlier though. It takes a couple of seconds for RB to generate a report, during which it doesn't respond. This is for me with a very small daily log compared to somewhere busy like Europe. (I typically only have around 100 aircraft a day...). Not a problem for me, but I guess if it was much bigger, it could take a lot longer.
Mike
AV61
Hi Alan
I have a virtual store  that it keeps loading into
Once I delete the virtual store copies I am ok but
Have to do it each time
Nick
AV61
Hi Alan
Have just tried deleting my virtual store copies and
Alas still have the same figure
How can I get rid of the virtual store copies  that keep appearing
Nick
Nick, the best way of avoiding all the virtual store problems is to NOT install in the default location.  Install in somewhere like C:\Airnav\Radarbox
Maybe the FAQ needs renaming to cover Vista/W7/W8 - http://www.airnavsystems.com/forum/index.php?topic=1570.0
AV61
I have just tried deleting the other folders and leaving the virtual store ones (the opposite of what I had to do before) and this time it has loaded the correct number of aircraft
Very strange bit so long as it works great
Thanks to all for your help and thanks to all who have worked so hard doing the upgrade
Nick
Michel
#39
Don't know if it's reported before; but when I email the daily log, only half of the log is mailed. I don't receive the complete log. Tried is several times, but no luck.
Michel.
Quote from: MichelDon't know if it's reported before; but when I email the daily log, only half of the log is mailed. I don't receive the complete log. Tried is several times, but no luck.
Noted, on task system as FS#273.  Only seems to affect daily logs sent using the Airnav server rather than a user-defined server.
I think it must be size related.  Mylog to mode-s has only 136 aircraft and it is complete.
Michel
QuoteI think it must be size related.  Mylog to mode-s has only 136 aircraft and it is complete.
Could be size related indeed. Yesterdays log contains over 400 entries, and the email ends with registrations starting SE-. Todays log contains 126 at the moment, and I receive the complete log when mailing.
Michel.
Michel
Just checked mailing again. When more than 390 flights are logged RB won't mail the complete log, but cuts it off.
Michel.
This has been logged as a bug - task FS#273.
