New AirNav RadarBox 5.00.53 Beta Upgrade
Started by AirNav Development, November 01, 2013, 09:20:28 AM
#60
I'm aware of the reason for the report being slow, and that has been raised with the AirNav Developer.  The MyLog should be very responsive now given the performance changes made for v5.00.053.
Just to confirm, and in answer to PMs, these are the additional bugs that Airnav now have on their task list:
    273 Daily Log Report Truncated
    274 Email log to multiple recipients fails on custom server
Busy over the last few days working with Airnav testing fixes for the remaining bugs.  Almost there..................
John Racars
Hi All,
just downloaded the new version after using 4.03 for many years. I am verry impressed of the the result. It looks it is a great advancement in comparison of 4.03.
Verry good progress so it looks. Much faster and more accurate.
Thanks to the Beta-testers and hope you will keep the verry good work up! Thank you verry much for doing this.
Best Regards, John
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
tommyg
Guys.
An interesting scenario occurred over the weekend. My log was showing 265 aircraft being picked up which I have never had before, even in summer on a good day I have only had just under 200 in the log. I noticed on my map that aircraft from 4 hours previous were still showing but not moving. I restarted the RB and lo and behold my log dropped to 116 aircraft which is my average especially on a wet and windy November day and a lot of aircraft disappeared from the map view. Has anyone else had this with the new beta?
tommyg
Tommyg
Dana
Problem with Timeout of MyFlight persist here .
If I set less than 5 sec to mark a flight as timeout all airplanes on the map and list are continuously changing their status from timeout to cruise  from cruise to timeout.
Also,I noticed on my map that aircraft from 1 or 2 hours previous were still showing time to time as timeout but not moving.
Dana
dumpty
I am getting the same problem as Dana above.
Aircraft that have timed out are still showing on the map much later.
Quote from: DanaIf I set less than 5 sec to mark a flight as timeout all airplanes on the map and list are continuously changing their status from timeout to cruise  from cruise to timeout.
What settings do you have for "Timeout for MyFlights" and "Screen Refresh Rate"?
Tommy/Dana,
Frozen time out flights issue reported on system as FS276
shouriken
Liviu
A.net JetPhotos.Net
RadarBox
#69
Thanks Liviu,
Will have it looked into, logged as FS 277.
Kacek
Yesterday I upgraded RB from ver 4.03 to 5.00.053 but now there is no flights in vertical tracking view.  Is this due to the beta version of RB or is it something wrong?
It looks like everything else works as it should at the moment.
Thanks for help
Kacek
Dana
Hi Tarbat,
My setting are:
Sec to make a flight as timeout 5 . If i set less all flight looks like timeout.
Sec to remove timeout flights are 2.
And about screen refresh rate are 1000ms.
Thank you.
dana
Kacek,
Reported to the tracking system FS278
John Racars
Hi All,
I am trying to edit the routedatabase with SQL. SQL give the error message "file is encrypted or is not a database".
What's going wrong. In version 4.03 editing the NavData.db3 was Always possible.....
Any help will more then welcome.
Thank you in advance!
13 NM East of EHAM
ANRB:
shouriken
It seems you missed the announcement of the 5.00 Beta:
QuoteNew features:
Sending emails by custom server
Encrypt navdata.db3 file
All comms to/from server encrypted
Users who don't share flight data or are not subscribed to the network will not received flight (photo/route information from server
http://www.airnavsystems.com/forum/index.php?topic=7914.0
Liviu
A.net JetPhotos.Net
RadarBox
