Started by orkney, November 07, 2013, 02:30:03 PM
jacobite
Greetings Alan, received just over half an hour ago, CS-GLC  491D83  I believe type is a GLEX is that correct please.
CYYZGUY
#1067
SWG660
CGA694
No Route
regards,
Merry Christmas!
Jason
40" LED Monitor
40" LED Monitor
Hi Ian,
Yes correct another GLEX for NetJets Europe c/n 9533
Merry Christmas Jason,
SWG660 CYYZ-MUCU
CGA = Congressional Air A biz outfit.
CYYZGUY
40" LED Monitor
40" LED Monitor
Hi Jason,
Today it runs UAL1100 KEWR-KSEA-KIAH
flygfantast
Quote from: Runway 31The only VQ-BOR I can find details of is 4245C3 VQ-BOR Canadair CL-600-2B19 Regional Jet
CRJ-200ER c/n 7535 Ak Bars Aero.  Nothing on Skyliner etc about it going elsewhere but time will tell.
Skyliner now has info on the aircraft and it's seems its the one you mention. Delivery 24dec13 YYZ-YYR-KEF-DME
Niklas
Cable: Ecoflex-10 (10m+1m)
Thanks for thr confirmation Niklas
Some unknonws from the past two weeks in loose order (five per posting)
3F6CA3 GAF183
49D088 (Czech Republic, no flight id, no active airframe found)
4A81BF (Sweden, no flight id, nothing more)
4CA76B (Ireland, no flight id, no active airframe found)
00BD05 (South Africa, no flight id, ZX-XCE AT72 of solenta aviation FR24: http://www.flightradar24.com/data/airplanes/zs-xce )
Batch #2
3A743C (France, no flight id, nothing more)
3C09DA (Germany, no flight id, nothing more)
3C659B (Germany, no flight id, nothing more)
3FF242 (Germany, flight id: DMVPP, D-MVPP no luck with the details)
400DB7 (UK, no flight id, G-ONAL last eyeballed in 2009)
Batch #3
4248C2 (UK, no flight id, nothing more)
484B8B (Netherlands, no flight id, wa PH-1304 which is now OK-1304)
4B843C (Turkey, no flight id, nothing more)
4CA11B (Ireland, no flight id, was(is) EI-CIW MD83 Meridiana)
AAC132 (USA, no flight id, decodes N792TX nothing on this REG)
Batch #4
155A3D (Russian Federation, no flight id, nothing more)
1C6462 (Russian Federation, no flight id, nothing more)
305FEB (Italy, no flight id, nothing more)
3C6609 (Germany, no flight id, decodes to D-AIPI, but nothing about an airframe using this REG)
471EAF (Hungary, no flight id, no active airframe found)
4B842B (Turkey, no flight id, no active airframe found)
4B8472 (Turkey, no flight id, nothing more)
4CA560 (Ireland, no flight id, no active airframe found)
4CC3EE (Iceland, no flight id, nothing more)
4D02F9 (Luxembourgh, no flight id, no active airframe found)
8405D5 (Japan, no flight id, nothing more)
A2D927 (USA, no flight id, no airframe using this REG found)
Hi Ingo,
I have no info on any of these other than what you have stated.
Michel
Alan,
LCO1507 EHAM-EDDF-SBKP iso EDDF-SBKP
Michel.
