Started by orkney, November 07, 2013, 02:30:03 PM
John Racars
#135
No problem. I understand now. After Andrew said "all are in" I thougt they are in the database from that moment on. I checked some attributies from yesterday and saw that all is allright!
Regards, John
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
CYYZGUY
40" LED Monitor
40" LED Monitor
X
#137
New Belarus in and out of DWC, possibly an IL76 delivering equipment for airshow.
* 510076   RSB2102                                                              2013/11/12 03:41:05
Hope you enjoy the drive on way back to dreich but Bonnie Scotland...I and Paul are in 30C and very sunny!
X
mikek
Not populating:
C81871, c/s ZKIAL.
ZK-IAL, Sikorsky S-76A, 76-0133, Northland Emergency Services Trust.
Must have been recently modified as it's been around for ages, but not on Mode S. Is now full ADS-B.
Mike
John Racars
Goodmorning Updaters,
in my post #123 I made a suggestion for correction a flight route. May I ask why this suggestion is not processed?
13 NM East of EHAM
ANRB:
orkney
Hello Mike, John, X and Jason
Mike, your one is added now.
X, I cannot find anything about your IL75
Jason, Your one is added.
John, I did correct your one in post 123 and it was on the server when I checked. I have uploaded thechange again to see if it will work for you this time.
Many thanks once again.
Andrew
Morning Andrew,
TCX49TK : LEAL-EGCC
John Racars
Quote from: orkneyJohn, I did correct your one in post 123 and it was on the server when I checked. I have uploaded thechange again to see if it will work for you this time.
Hi Andrew,
Thank you; I will keep an eye on it.
13 NM East of EHAM
ANRB:
Michel
Some more:
SVA23 OERK-KJFK iso OERK-ESNO-KJFK
NVR147 ENGM-GCFV
DLH6CF EGLL-EDDT iso EDLL-EDDT
VKG2603 ESGG-GCTS iso ESGG-GMAD
EZY88CF EGAA-EPKK
AWE799 EHAM-KPHL iso KPHL-EHAM
Michel.
orkney
Hello Michael and Ian
I have done all your additions and changes.
Many thanks once more.
Andrew
John Racars
#145
FN NO ND NV NO ND NV
New:
AFR172B LFPG EDDM
BCS7101 LIME EBBR
BCY70A EHRD EGLC
BCY84EG EHAM EGLC
BCY87MK EGLC EHAM
BEL23Z EKCH EBBR
BMR14IW EGBB EKBI
BTI60K EVRA EBBR
CAO1026 EHAM ZBAA LEZG
CFG442 EDDL LEJR
CFG443 LEJR EDDL
CKS246 EHAM KJFK
CLX715 HKNA ELLX EHAM
CSN475 ZGGG EHAM ZUCK
EZY46DX EGCC HESH
EZY68GB EGSS EDDM
EZY68MF EGPH EDDB
EZY88CF EGAA EPKK
JTG936 GCFV EFHK
SQC7135 WSSS EHAM OMSJ
SQC7136 EHAM WSSS OMSJ
SWR33K LSZH EGCC
SWR36C LSZH EGLL
TFL453 EHAM GBYD
TFL461 EHAM HKMO HEGN
TRA854 GCTS EHEH GCRR
UPS208 EDDK KEWR
UPS236 EDDK EGSS
UPS242 EDDK LEBL
UPS256 EDDK LEMD
WZZ83M EHEH EYVI
Correction:
TRA853 EHEH GCRR GCTS i.s.o. EHAM LEPA LEIB
13 NM East of EHAM
ANRB:
orkney
Hello John
That is that set uploaded too.
Thank you
Andrew
Michel
Some more:
TCX72KN EGCC-LCPH
BEE2GA EGNX-EHAM iso EGNX-EGAM
EZY15EV EGCC-LIPZ
EZY94UV EGNT-LMML
CFE83E ESSA-EGLC iso LEPA-EGLC
UAE9909 OMDB-EHAM-ESGG iso OMDB-ESGG-EHAM
Michel.
Evening, the unknowns from Monday:
* 3991EB  AFR1944  LFPG-UUEE                                             2013/11/11 09:48:14
* 3C492A        2013/11/11 07:59:31
* 3C49AD        2013/11/11 18:17:21
* 3C5CAB        2013/11/11 10:09:52
* 3C6574        2013/11/11 06:16:48
* 3C660A        2013/11/11 20:35:11
   3D0E18  DEDOY                                                          2013/11/11 10:50:09
* 3E8145  GAF099                                                         2013/11/11 09:27:54
* 3E9236        2013/11/11 10:17:45
* 3E9984  GAF120                                                         2013/11/11 12:26:54
* 3E9984  GAF120                                                         2013/11/11 13:15:09
* 3E9BAA        2013/11/11 08:27:51
* 3E9BAA        2013/11/11 09:08:43
* 3EA603  TA45                                                           2013/11/11 09:40:25
* 3EB713        2013/11/11 12:48:31
* 3EB713        2013/11/11 13:46:11
* 3EBBFE  HG01A                                                          2013/11/11 09:35:53
   3F462C  BU17T                                                          2013/11/11 10:29:41
   3F462C  BU17T                                                          2013/11/11 11:23:34
   3F4759  EAGLE1                                                         2013/11/11 14:05:11
   3F4AA8  PANTER                                                         2013/11/11 09:31:20
* 3F533F  GAF222                                                         2013/11/11 08:49:26
* 3F5590        2013/11/11 08:30:45
* 3F5590        2013/11/11 09:09:59
   3F5EF7  GAF163                                                         2013/11/11 11:48:43
   3F5EF7  GAF163                                                         2013/11/11 14:50:47
   3F70F1  TA54                                                           2013/11/11 08:59:40
   3F79B2  SMASH                                                          2013/11/11 08:25:23
* 3F8A7F        2013/11/11 12:51:14
* 3F8A7F        2013/11/11 14:13:27
* 3F8DE2  GAF063                                                         2013/11/11 10:02:22
   3F8E31  GAF091                                                         2013/11/11 14:53:40
   3F989B  VADER2                                                         2013/11/11 08:42:53
* 3FA0E4  BOMBER                                                         2013/11/11 09:10:53
   3FAF12  GAF183                                                         2013/11/11 08:40:29
* 3FAFDB        2013/11/11 18:35:20
   3FF19B  DMCBP                                                          2013/11/11 12:56:00
* 3FF1ED  DMLUS                                                          2013/11/11 15:00:51
   3FF287  DMFFM                                                          2013/11/11 11:56:05
   3FF287        2013/11/11 12:43:50
* 3FF2AE  DMATC                                                          2013/11/11 15:07:31
   445566        2013/11/11 08:13:51
* 463A8A        2013/11/11 09:48:53
* 484151        2013/11/11 20:42:56
* 48ADA6        2013/11/11 19:55:25
   4CA906        2013/11/11 11:09:29
   4CA906  XJC999                                                         2013/11/11 13:45:54
* 503C4A        2013/11/11 20:09:45
* A0732F        2013/11/11 09:37:14
* A754B9        2013/11/11 06:37:37
Hi Ingo,
The German Air Force was out in  force on Monday with all those unknown tactical codes on display.
Other than that the only other tied up was D-MATC BRM Bristell NG5 c/n 034/2013
