Started by orkney, November 07, 2013, 02:30:03 PM
Xon
Good Evening,
the unknowns from Tuesday:
* 1803C0        2013/11/12 18:19:39
   3C2D57        2013/11/12 08:20:43
   3C2D57  QGA261R                                                        2013/11/12 11:25:43
* 3C542D        2013/11/12 07:06:37
   3C546C  DLH1489  UMMS-EDDF                                             2013/11/12 05:04:08
   3C6DC5  GWI7F                                                          2013/11/12 14:25:42
   3D3A54  DEUIM                                                          2013/11/12 05:53:56
   3D3A54  DEUIM                                                          2013/11/12 16:03:03
* 3E8053  GATOR                                                          2013/11/12 14:13:26
   3EA33B        2013/11/12 13:19:17
   3EA89C  SNAKE                                                          2013/11/12 16:37:31
   3EBAE9  GAF101                                                         2013/11/12 07:11:25
   3EBAE9  GAF101                                                         2013/11/12 08:03:56
* 3F57F9  MI26MC                                                         2013/11/12 13:02:35
   3F70E3  BURNER2                                                        2013/11/12 10:04:31
   3F70E3  BOMBER2                                                        2013/11/12 13:44:07
* 3F759F        2013/11/12 14:56:25
   3FA814  BURNER1                                                        2013/11/12 09:31:03
   3FA814  BOMBER1                                                        2013/11/12 13:37:26
* 3FB42D  BU24T                                                          2013/11/12 14:17:14
   3FEFE9  DMDDO                                                          2013/11/12 06:53:45
   3FEFE9  DMDDO                                                          2013/11/12 13:32:07
* 400B8B        2013/11/12 05:41:43
* 4401E7        2013/11/12 19:00:59
   445566        2013/11/12 20:24:56
* 459AED        2013/11/12 12:19:38
* 461E10        2013/11/12 11:05:49
* 461E10        2013/11/12 19:37:51
* 484ACF        2013/11/12 17:56:44
* 4951B3  TAP594   LPPT-UUDD                                             2013/11/12 22:23:36
* 4BA99E        2013/11/12 13:46:36
* 505C68  TVS1038  LKPR-LFPG                                             2013/11/12 11:49:47
* 505C68  TVS1039  LFPG-LKPR                                             2013/11/12 14:38:07
* 80A0E4        2013/11/12 14:48:38
* 986F0B        2013/11/12 14:54:03
Regards Ingo
orkney
Hello Xon, Ingo and Michel
That is all of them done.
Ingo - 505C68 is the only one of yours I can find anything worthwhile about.
Thank you
Andrew
John Racars
FN NO ND NV NO ND NV REMARKS
New:
BEL11C EGBB EBBR
BEL12F LIML EBBR
BEL25X EDDH EBBR
BEL27H ESGG EBBR
BEL34N EGCC EBBR
BEL3SV EBBR LSGG
BEL4CP EBBR EKCH
BEL4RR EBBR EDDT
BEL4SM EBBR LFSB
BEL50V EGBB EBBR
BEL56M EKCH EBBR
BEL58Y EDDV EBBR
BEL67C LIRF EBBR
BEL70V LKPR EBBR
BEL98P LFST EBBR
BEL9KT EBBR EGBB
DLH4AJ EDDF EGLC
DLH4MM EDDF EGLL
DLH67Y EDDT LFPG
DLH6EP EDDM EBBR
EZY1872 UUDD EGCC
TFL462 HKMO EHAM HTZA
TFL949 EHAM HEGN HEMA
WZZ4XP LHBP EBCI
WZZ9JS EBCI LROP
Correction:
DLH3CK EDDH EGLL i.s.o. LROP EDDF
DLH9JE EDDF EBBR i.s.o. EDDH LYBE
No route:
DLH9JE IN D/B; NO INFORMATION
KLM875 IN D/B; NO INFORMATION
PIA710 IN D/B; NO INFORMATION
RYR601K IN D/B; NO INFORMATION
THY6ZA IN D/B; NO INFORMATION
UAE19 IN D/B; NO INFORMATION
UAE25 IN D/B; NO INFORMATION
UAE3 IN D/B; NO INFORMATION
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
Michel
48480D is in d/b as a Bolkow 208C PH-HVD, which can't be right. It but must be a Netherlands Airforce F16, but unfortunately I don't know which one.
X
#170
43E8F8  MJE013                                                         2013/11/13 21:50:21
This was M-OMAN FA7X but d/b states this frame is now P4-GIS.
Have you made it to Scotland yet?
PS. New RadarBox 5.00 is a big improvement! No issues at all except just a bit slow to load the reporter at around 2 seconds.
X
#171
Michel,
Netherlands civil aircraft use 484*** and 485*** hex codes. Netherlands Military aircraft use 480*** and 481*** hex codes and from AvDv gives 48480D is given as PH-HVD the Bolkow as does GAS http://www.gatwickaviationsociety.org.uk/modeslookup.asp
Ala
orkney
Hello X, Michael and John
John - All of your ones are now done.
Michel - This mode S code is allocated to the Bolkow -http://www.newfoundland.nl/luchtvaartregister/user/en/luchtvaartuig.php?registratie=PH-HVD if a F16 was using it it shouldn't be.
X - P4-GIS is cn 139 M-OMAN, was cn 138. Cn 138 according to the database is now A6-MBA of Empire Aviation (This ties in with the callsign you posted) so I have added 43E8F8  as miscode of  A6-MBA.
Many thanks all of you once more.
Andrew
Michel,
Netherlands civil aircraft use hex codes in the 484*** and 485*** hex code range with military aircraft using the 480*** and 481*** codes.  AvDb and GAS both give the Bolkow for 48480D
Michel
I don't know what, but something is wrong with 48480D. I've logged it several times at altitudes like FL330 and with callsings as Metal01, Sting01 and Fist01 which are typical Dutch AF F16 callsigns. I've "seen" it flying at FR24 since they have MLAT and speed is exceeding 440 knots. That's why I have my doubts about this one.
That being the case then Michel, with that additional information the F16 must be miscoding the civil hex.  I will mark it as in use by more than one aircraft.
John Racars
New:
CFG125 GCLP EDLP
DLH21A LEBL EDDL
DLH9AJ EBBR EDDM
EZY19FP EDDM EGKK
EZY37UY LOWW EGKK
FDX5279 LFPG KMEM
WZZ1FE LKTB EGGW
WZZ2XS EBCI EPWA
Correction:
DLH21A LEBL EDDL i.s.o. LPPT EDDM
GWI3CP EGSS EDDK i.s.o. EGSS EDDV
WZZ2GK EGGW LBSF i.s.o. EGGW LFBS
13 NM East of EHAM
ANRB:
Xon
Quote from: orkney on November 13, 2013, 06:01:00 PM
It's OM-HCA A320 c/n 4699 Travel Service
Thanks Xon,  BTW it was added to the database yesterday after operating TVS1038/1039 LKPR - LFPG - LKPR
