Started by orkney, November 07, 2013, 02:30:03 PM
superspotter
Cheers Alan and one more for tonight is Hexcode 06418C is 5N-RKT Allied Cargo 734, confirmed reg upon landing, regards clive.
Many thanks again Clive,
M
THY58D LTBA-EVRA
NWS3515   UUDD-MMUN (not UUEE-MMUN)
NWS3516   MMUN-UUDD (not MMUN-UUEE)
NWS3517   UUDD-MDPC
NWS3518   MDPC-UUDD
NWS3523   UUDD-MUVR
NWS3524   MUVR-UUDD
Xon
superspotter
Morning from Lagos;
Hexcode 06407D is 5N-MPN Be1900 Mobil Oil, reg as callsign.
One query though this morning, I have hexcode 044045 which is Ghanaian but with an Asky callsign, don't suppose you have anything for this Alan? I will try and determine aircraft type next time it appears, bit hazy this morning. regards clive.
X
SVR3089 has gone to UUDD-OMDW today not OMDB. Assume return is 3090
X
X
* 32C7E7        2014/01/10 00:48:00
X
Northern Watch
Good morning Alan
Picked up yesterday without an operator showing:
4B3906 / HB-VPM / Cessna 510 / From the pictures on the net the operator is MyJet.
Keith
Michel
Alan,
Not sure if you already got some of below TRA in the d/b. The DLH wasn't showing route info.
DLH455 KSFO-EDDF
TRA507R GMAD-EHAM
TRA610U LOWI-EHAM
TRA750P GMMN-EHAM
TRA13BC LIPZ-EHAM
TRA754X GMMX-EHAM
TRA36PN GCLP-EHAM
TRA86M GCRR-EHAM
TRA43EG EHAM-GCTS-GCLP
TRA278Y EHAM-GCLP
TRA85U EHAM-GCRR
Michel
Hi Clive,
Thanks for the B190.  Regarding the ASky, these are normally Ethiopian registered and as the hex decodes to 9G-TOP a DC8-63 I presume there must be a miscode at work and it should be a 0400** hex code.
Hi X,
Yes the auto routine indicates that it was an OMDW landing and take off.
I dont have any details on your hex code.
Hi Keith,
The Swiss onlone register http://www.bazl.admin.ch/experten/luftfahrzeuge/luftfahrzeugregister/index.html?lang=en gives the owner/operator as Philippe Foriel-Destezet
Many thanks again Michel
Northern Watch
QuoteHi Keith,
Hi Alan
The force must be with you as you never stop surprizing me with all your wealth of knowledge.
Keith
