Started by orkney, November 07, 2013, 02:30:03 PM
X
This flight carries on to OMDW, the return I assume is JTG770
JTG769   ESSA-HESH
X
The trick is finding out where to get the info Keith.
Northern Watch
Hi Alan
Maybe you can look in to this one C0637E that I have just picked up heading toward Stornoway.  It is showing as a miscode but the Canadian registry is showing it as C-GLRP, the same as its c/s but the details are for PR-FMS?
Keith
Hi Keith,
C0637E is now C-GLRP Learjet 45 c/n 45-2103 Skyservice Business Aviation registered 8/1/2014, two days ago and is the former G-HPPY de-registered 7/1/2014.  I would imagine its on its delivery flight
The previous C-GLRP had the same hex and is now registered PR-FMS and is/was presumably miscoding its former ID.
superspotter
Cheers for that Alan, I will continue to monitor that hex should it appear again. Incidentally, if I was to take your suggestion and change it to 040045, it is an Ethiopian 787 which showed up today too!
regards clive.
Northern Watch
QuoteHi Keith,
Thanks Alan
I knew you would have the answer, in this case I take it that you have amended the db to show this change and I will delete the picture of a helicopter from the Photos file and links from the db fields
Keith
It has been updated Keith.  This is the 4th use of the registration.
I woudnt think that it will be the case Clive, either a DH8D or a 737.
superspotter
Yes I would agree Alan as it was using an Asky callsign, just a coincidence re the 787 :)
Xon
510079 EW-386PA B733 c/n 24327/1712
Skyliner:
Boeing 737    -3K2    24327    1712    EW-386PA    Belavia    delivery 03jan14 VNO-MSP, in svc 08jan14 MSQ-FCO vv     ex LY-FLJ
Thanks Xon, updated earlier via John Hargreaves.
Thanks M, can find nothing on it yet but SE-LHI would seem likely given its earlier delivery date.
snj-5
Hello, I'm new to the forum.  I'm a pilot/aircraft owner but a novice at web-based aircraft tracking.
If you will forgive the intrusion, I found this thread via a Google search for N181CS (an ArkEx Dehavilland
Twin Otter).  My interest in tracking this particular aircraft is personal in nature...  My Fiance's son is
currently flying that Twin Otter home to the USA from North Africa.  He calls / Skypes us when he can, but
we'd like to be able to track his progress home (currently from Wick, Scotland, to the Faroe Islands,
Iceland, Greenland, Northern Canadian territories and finally down into the USA).  I've tried using various
global flight tracking web sites (this one, planefinder.net & www.flightradar24.com) but I've only been
able to find/track N181CS a couple of times with www.flightradar24.com while the aircraft was in the UK.
Is there a FAQ that describes what types of aircraft can be tracked and where (globally)?  I suspect that
particular Twin Otter probably has an old Mode C transponder and/or doesn't have any ADS-B equipment
onboard.  Thanks for any help (my apologies if this post doesn't belong here).
Bela P. Havasreti
