Started by orkney, November 07, 2013, 02:30:03 PM
superspotter
Hello again from Lagos;
Hexcode A7DA1E is N605DA CL605 according to the info on the net. However, the controller called up N105DA so it may be a reg change as this would follow with another resident here, N104DA. Don't know if you have any more info on this.
regards clive.
Hi Clive N605DA CL605 was certified less than a week ago on 12/11 and has A7DA1E allocated.  N105DA is an Air Tractor AT-301.  Would suggest the controller made a mistake.
superspotter
I would go with that, wouldn't be the first time, the ATC are hopeless here!
John Racars
#348
Quote from: CYYZGUYKLM47
No Route...Not sure if this is missing a zero or not.
It is my report all the time like this (reg change every day ofcourse) and so be it on the RB screen:
17-11-2013 12:09:43 KLM47 EHAM - KORD PH-BFD B744
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
Northern Watch
Hi Alan
Two more from today:
NVD873     BIKF - LDZA
BEL3ED     EBBR - EGPH
Keith
John Racars
#350
Verry sorry forgot to tell KLM47 is verry shortly in the d/b; so the total reports of KLM47 since this flight is in:
13-11-2013 11:52:39 KLM47 EHAM-KORD PH-BFA B744
15-11-2013 12:06:20 KLM47 EHAM-KORD PH-BFA B744
16-11-2013 12:14:26 KLM47 EHAM-KORD PH-BFK B744
17-11-2013 12:09:43 KLM47 EHAM-KORD PH-BFD B744
18-11-2013 11:52:49 KLM47 EHAM-KORD PH-BFF B744
Because this is a every-day flight the 14th of November must be fall out through maintanance on my PC or the RB databases and running my SQL reports at departure times of KLM47
13 NM East of EHAM
ANRB:
John Racars
FN NO ND NV NO ND
New:
CKS254 EDDP KCVG
EZY24RC EGKK EDDK
TAY916E EHAM EBBR
WZZ595 LZKZ EGGW
WZZ6AN LJLJ EBCI
Correction(s):
DAL470 KJFK EHAM i.s.o. KATL KBWI
TRA6846 GVSV EHAM GVAC i.s.o. EHAM GVAC
13 NM East of EHAM
ANRB:
Michel
Alan,
PRI242 GCTS-EFKU iso GCTS-EFSI
NVR156 GCFV-ESGG
VKG2684 GCFV-ESGG iso GCFV-ESMS
BER493J LEMG-EDDH iso LEMG-EDDT
SAS7904 LPMA-ESSA iso LTBS-ESGG
FDX5187 EHAM-LFPG iso ENGM-EHAM-LFPG
Michel.
John Racars
Hi Michel,
How about the FDX flight to LFPG? Schiphol info give this as dep as well. Where is the inbound of this (former ENGM)?
Schiphol gives no inbound of FDX flights. Verry strange.....
13 NM East of EHAM
ANRB:
Michel
John,
During the week, this flight is a day stop at EHAM. But there is no friday evening departure. So this one came in friday morning as FDX5188 from LFPG, and departs monday evening again. That's why you couldn't find the incoming flight.
Michel.
paul tricker
* ACDD0F        2013/11/19 08:50:30
= N928NA  WB57F  NASA
Just flew over the sandpit at 50K trailing!  V. Nice
Paul
Hi Paul,
I agree that is what this should be but it is worth mentioning that the aircraft was deleted from the FAA list earlier this year.
