Started by orkney, November 07, 2013, 02:30:03 PM
John Racars
Quote from: Runway 31My error with AFR424F
No problem ofcourse Alan. Always thought you copied my data in your database 1 on 1after my contributions judged to have so nothing should be wrong. This is not the case so I understand now.
But I've decided to provisionally stop supplying contributions. Too much coincidence.
Best Regards,
John
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
Northern Watch
Hi Alan
My apologies reference BEE3435, I miss read it.
Keith
#377
John,
I dont see any co-incidence, Michel and yourself are both in the Amsterdam area and so will pick it up around the same time.
I require to type each flight callsign along with the Origin, departure and via points into the updater John, I cannot cut and paste.  Unfortunately I am human and can make mistakes during the typing and in this case instead of typing the origin into the origin box I typed it into the flight number box instead and didnt notice.
Where I make an error and dont notice at the time it is then there for all the world to see unfortunately and usually require a user to alert me as in this case.
Michel
Alan,
EZY7156 LCLK-EGGP iso GCRR-EGGP
John,
Just keep on posting your updates. You got your box running 24/7, I don't. So you will notice more incorrect/missing routes than I do. It's better to have 2 persons with the same updates, than none.
Michel.
Michel,
EZY7156 is LCLK-EGGP in the d/b since 9/11 but thanks anyway
Northern Watch
Hi Alan
A correction on the routes list going back to the problem we had with LOG49FW.  I believe this is now flying the following route which has been constant now for the last few days:
LOG49FW       EGPB - EGPH and not EGLC - EGPH as per d/b.
Keith
Cheers Keith, never did I think to was EGLC, many thanks
We have 2 deliveries to Myanmar Airways International out of Shannon at this time 704458  XY-AGV  Airbus A319-111  c/n 1247 and its sister ship 704457  XY-AGU  Airbus A319-111  c/n 1180  in front
Morning Alan,
THY5KF is in d/b as LEMG-LTBA. It should be LTBA-LEMG.
Alan,
Just to inform you that I have finally got a Manx registered plane on 'My Flights' and can confirm that the Manx flag is now showing again.
Good to know Ian, thanks
You would have thought I woul have noted the Malaga flight!
GreekSpy2001
typo in database?
TAM 777 E48DF6 is showing as PT-TUI and not PT-MUI
Graham
Xon
48D82F 0225 AN28 c/n AJG004-08
Correct, thanks for advising Graham, appreciated
