Started by orkney, November 07, 2013, 02:30:03 PM
John Racars
FN REMARKS
No route:
DLH947 IN D/B; NO ROUTE
KLM1094 IN D/B; NO ROUTE
RYR3788 IN D/B; NO ROUTE
UAE5 IN D/B; NO ROUTE
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
I presume this is while the server is down John
John Racars
FN NO ND NV NO ND NV REMARKS
New:
GEC8160 EDDF KJFK
TOM56C LCPH EGCC
WZZ7 EHEH LRCL
Correction(s):
GTI8903 KJFK EDFH i.s.o. KORD VHHH PANC
No route:
CLX772 IN D/B; NO SHOW
EZY35VB IN D/B; NO SHOW
GTI8903 IN D/B; NO SHOW
MON641 IN D/B; NO SHOW
13 NM East of EHAM
ANRB:
John Racars
Quote from: Runway 31I presume this is while the server is down John
Good evening Alan,
most of all flights are showing their flightinfo as it should be overhere at the moment. Just the ones I reported to you are not. I do not understand why this is. They are all in my local database so I do not understand what this have to do with "server is down".
Thanks again in advance for your reaction; there is no need for hurry to answer.
13 NM East of EHAM
ANRB:
John,
The server is back online now.  My technical knowledge is limited but it is all to do with checking that the correct aircraft is getting the correct call sign applied and the aircraft is being correctly identified according to its hex code.  There is lots of checking goes on and why some dont show their route at times is beyond my knowledge.
You may have notices in the previous version there were decoding errors and you may also have seen the wrong flight ID being applied to the wrong aircraft or even to more than one aircraft, that doesnt normally happen now.
Maybe someone with better knowledge than me can give a detailed answer and an email to support may provide you with the full technical details of how the route look up routine works.
John Racars
Alan,
thank you for your clear reaction. There is no need to be more specific; you made the principle clear to me more than enough and I know enough now. Thank you for that!
Does it still make sense to report flights without route-info while in the d/b to you?
Thanks again for your fast and clear reaction!
13 NM East of EHAM
ANRB:
If the route is in the database correctly John there is normally no need to advise me
John Racars
All right Alan. I will check my database in the first place. If everything looks OK I will not report flights like this to you anymore.
I will report any new and corrections (if you agree) to you only.
13 NM East of EHAM
ANRB:
Many thanks John, all assistance greatfully received.
Michel
Alan,
Some more Scandinavian stuff:
BLX216 GCLP-ESSA
BLX268 GCLP-ESGG iso GCLP-ESGG-ESSA
BLX666 GCLP-EFHK iso GCLP-ESSA
NVR146 GCLP-ESGG
NVR174 GCLP-ESSA
PRI244 LPMA-EFJY
VKG1684 GCLP-ESSA
Michel.
John Racars
#416
FN NO ND NV
New:
CKS412 ETAR KWRI
FDX9141 KMEM EDDK LFPG
NAX9343 GCLP ENVA
TFL672 GCTS EHAM
WZZ451 EPGD EGCN
Correction(s):
WZZ2GK EGGW LBSF i.s.o. EGGW LFBS
13 NM East of EHAM
ANRB:
CYYZGUY
#419
UAL1212
UAL1253
No route
regards,
Jason
40" LED Monitor
40" LED Monitor
