Started by orkney, November 07, 2013, 02:30:03 PM
John Racars
FN NO ND NV
New:
BCY30H EBAW EGLC
BCY34H EBAW EGLC
BCY71B EGLC LFRG
BCY76C EDDN EGLC
DLH1CH EDDL ESSA
DLH1KW EDDL EPKT
DLH6JT EDDL EDDT
DLH947 EGCC EDDF
EZY35VB EGCC EHAM
KLM1094 EGCC EHAM
NAX9342 ENVA GCLP
NVR146 GCFV ESSA
NVR167 ENGM GCLP
NVR173 ESSA GCLP
NVR174 GCLP ESSA
PIA709 OPLA EGCC
PIA710 EGCC OPLA
PRI243 EFJO LPFU
PRI244 LPFU EFJO
SQC7359 EHAM WSSS EKCH
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
Hi Jason
UAL1253 KLAS-KEWR
UAL1212 KSFO-KSEA yesterday KEWR-KSFP-KPDX today, will not enter in d/b
Many thanks again John,
I have a bit of a dilema here with a couple of the flights and their routes.
You gave today the following-
NVR146   GCFV   ESSA
PRI244   LPFU   EFJO
Yesterday Michel gave the same ones as -
NVR146 GCLP-ESGG
PRI244 LPMA-EFJY
I cannot find any definative details on either and would appreciate it if these could be checked please
Northern Watch
Good evening Alan
Just thought I would add my findings to your dilemma over the two flights.  It looks as if NVD146 has been flying  GCFV -  ESSA recently.  However, PRI244 has been flying predominately from LPFU but landing at various destinations in Finland.  EFJY, EFPO and EFOU have been used.  I hope this helps.
Keith
John Racars
Quote from: Runway 31I have a bit of a dilema here with a couple of the flights and their routes.
Good evening Alan,
I am verry sorry to bring you in a situation like this. I am affraid this can and should happens more when 2 persons in the same area of reception using different sources.
Please feel free to ignore my attributes in this case.
13 NM East of EHAM
ANRB:
John/Keith
Its the unfortunate situation with charter flights that the same flight  ID can be used on various routes even in the same week.  What is correct one day can be wrong the next ,bah!!
Michel
Alan,
NVR146 did flew GCLP-ESGG, and PRI244 did flew LPMA-EFJY yesterday. Checked both flights on FR24, and on the arrival boards of Gothenburg and Jyvaskyla. You can discuss if LPMA or LPFU is the correct ICAO code for Madeira/Funchal.
But it could be NVR and PRI use some flightnumbers at random.
Michel.
I will stick to LPMA for Funchal, Madeira
John Racars
Here again a list. I do notice some of these may or may not.
FN NO ND
Proposals to add on the AirNav Route d/b:
BOX116 EDDP EBBR
DLH7ET EBBR EDDM
GWI8XP EGSS EDDK
NAX9843 EFHK GCLP
WZZ446 EGCN EPWR
WZZ708 EPWR EGCN
13 NM East of EHAM
ANRB:
Many thanks again John, much appreciated
M
There was some discussion about PRI244... Here's a list of PRI2xx routes which have been active in November. The routes from EFHK are static, but for PRI241/2, 243/4 and 247/8 the airport in Finland changes every week. I have changed these routes in my own NavData database to EFZZ, for example PRI244 LPMA-EFZZ.
PRI227   EFHK   LLOV
PRI228   LLOV   EFHK
PRI229   EFHK   GCTS
PRI230   GCTS   EFHK
PRI239   EFHK   GCLP
PRI240   GCLP   EFHK
PRI241   EFJO   GCTS   04nov
PRI241   EFKU   GCTS   11nov
PRI241   EFRO   GCTS   18nov
PRI242   GCTS   EFJY   04nov
PRI242   GCTS   EFJO   11nov
PRI242   GCTS   EFKU   18nov
PRI243   EFPO   LPMA   06nov
PRI243   EFJY   LPMA   13nov
PRI243   EFJO   LPMA   20nov
PRI244   LPMA   EFOU   06nov
PRI244   LPMA   EFPO   13nov
PRI244   LPMA   EFJY   20nov
PRI245   EFHK   GCFV
PRI246   GCFV   EFHK
PRI247   EFJY   GCLP   05nov
PRI247   EFJO   GCLP   12nov
PRI247   EFKI   GCLP   19nov
PRI248   GCLP   EFPO   05nov
PRI248   GCLP   EFJY   12nov
PRI248   GCLP   EFJO   19nov
Thanks M, no wonder there have been differences of opinion on those routes, your EFZZ looks a good compromise
Kenny
AIQ2798 VTBD VVTS
CES5035 ZUUU VTBS
New unknown
* 84BD16  SFJ5862                                                        2013/11/20 14:04:31
* 4241D2  TBJ33    YMTG-YMEN                                             2013/11/21 15:15:52
I think the airline name should be just Malindo Air
9M-LNJ      B739  Malindo Airways
http://en.wikipedia.org/wiki/Malindo_Air
ANRB 3km north of VTBD
CYYZGUY
40" LED Monitor
40" LED Monitor
#434
Hi Alan:
Not populating: 80517E and 7CC39E
