Started by orkney, November 07, 2013, 02:30:03 PM
Hi Jason
All that data is derived from the Hex (Mode-S) code so it would help if you could tell us that.You can turn the display of that code in the grid through File...Preferences..Legends and Labels in the Grid Visible Columns box.
CYYZGUY
Hi Rod, I think it is C034BA
Does that help?
regards,
Jason
40" LED Monitor
40" LED Monitor
Maybe it hasn't been added to the server database yet. There are only 2 flights in the history
at FR24, both yesterday. details: http://www.flightradar24.com/data/airplanes/c-ftzd
Unknowns 27th of November:
3C459E (Germany, no flight id, nothing more)
3C48C0 (Germany, no flight id, nothing more)
3E19F6 (Germany, flight id: DIBAK, already in db )
3E53AF (Germany, no flight id, nothing more)
3E835B (Germany, no flight id, nothing more)
4242DB (UK, flight id: MMM9625, MMM: Meridian Air (Russia) )
43E9C0 (UK, flight id: MIRON, M-IRON Embraer EMB-135BJ Legacy 600 14501176 Private source: FR24)
45ACC0 (Denmark, no flight id, nothing more)
470D43 (Hungary, flight id: FAH6PG, FHA: Farnair Hungary, HA-FAP Beech 1900C-1 Farnair Hungary UC-66 source: FR24)
4B18E4 (Switzerland, no flight id, nothing more)
75830A (Phillipines, flight id: PAL008, RP-C8784 Airbus A330-343X Philippine Airlines 1467)
A3521B (USA, flight id: DIKAH, matches to N313BM, D-IKAH is in db. But maybe there is a change to be done...)
AA5195 (USA, no flight id, would match to N764NE but nothing on this reg.)
MIL:
3E85AC  HAMMER2                                                        2013/11/27 08:28:35
   3EA433  HAMMER1                                                        2013/11/27 08:18:46
   3EFCB0        2013/11/27 13:31:21
   3F486E  LK01A                                                          2013/11/27 18:41:23
   3F8446  SMASH                                                          2013/11/27 08:03:32
   3F885C  HG01A                                                          2013/11/27 07:16:12
   3F885C  HG01A                                                          2013/11/27 11:12:37
* 3F9BF2  GAF254   BIKF-ETNH                                             2013/11/27 11:11:27
* 3F9FFE  UGLY                                                           2013/11/27 08:19:24
   3FB645  TA52                                                           2013/11/27 11:45:29
   3FB645  GAF740
Regards Ingo
Unknowns November 28th:
3C5CA7 (Germany, no flight id, D-AGEG withdrawn from use in 2012)
3E5402 (Germany, no flight id, nothing more)
4009C2 (UK, no flight id, ex. G-GSSB B744, nothing about a new one)
4242DB  MMM9626 see previous posting)
445566 (Austria, no flight id, again...)
4B1782 (Switzerland, no flight id, nothing more)
4CA76B (Ireland, no flight id, nothing more)
4CA76D (Ireland, no flight id, was EI-EDO, nothing about a new one)
4D20A4 (Malta, no flight id, nothing more)
523BE1 (no allocation, flight id: N9488B, N9488B is in db with MS AD2E52)
MIL:
   3E85AC  PACK1                                                          2013/11/28 14:08:45
   3E92DD  PACK4                                                          2013/11/28 14:19:36
   3E9DCE  PACK3                                                          2013/11/28 14:18:37
   3E9EF7  SW82                                                           2013/11/28 18:30:03
   3E9EF7  SW82                                                           2013/11/28 19:22:26
   3EFCB0  SW83                                                           2013/11/28 18:32:34
   3EFCB0  SW83                                                           2013/11/28 19:28:48
   3F57F9  GAMC52                                                         2013/11/28 16:41:06
   3F57F9  GAMC52                                                         2013/11/28 18:20:23
* 3F6671  REAPER                                                         2013/11/28 07:21:12
   3F6A89  BONEST                                                         2013/11/28 08:27:22
   3F6A89  BONEST                                                         2013/11/28 09:22:31
* 3F733D  GAF504                                                         2013/11/28 08:54:09
   3F7DE5  SMASH1                                                         2013/11/28 13:52:30
   3F8672  GAF081                                                         2013/11/28 07:04:09
   3F8672  GAF081                                                         2013/11/28 13:33:52
   3F885C  HG01B                                                          2013/11/28 07:19:11
   3FB645  GAF740                                                         2013/11/28 07:51:42
Regards Ingo
Unknowns November 29th:
00FFF7 (South Africa, no flight id, previously identified as a miscoded MIL airframe)
1D0769 (Russian Federation, no flight id, nothing more)
3C489D (Germany, no flight id, nothing more)
3CA6C9 (Germany, flight id: DBIVI, D-BIVI Bombardier BD-100-1A10 Challenger 300 ProJet Mk1EB: http://flugzeugbilder.de/show.php?id=1263847 )
3E19F6  DIBAK already in db
400572 (UK, no flight id, no active airframe found)
424134 (UK, flight id: WGT53S, was(is) VP-CAN A319)
43E9C0  MIRON already posted
44005C (Austria, no flight id, was OE-BBB BE20 nothing about a new one)
470D43 already posted
48932F (Poland, no flight id, nothing more)
4B9061 (Turkey, flight id: PGT902, TC-DCA Airbus A320-214 Pegasus Airlines 5879, I'll bet it's already in db but wasn't in my range again, so it has not populated until now.)
780B88 (China, flight id: CSC6449, B-6449 Airbus A319-133 Sichuan Airlines 5868, same as above)
A528A1 (USA, no flight id, matches to N431UK, nothing on this reg.)
MIL:
   3E85AC  SHOCK03                                                        2013/11/29 08:30:01
* 3E8DFC  GAF926                                                         2013/11/29 09:09:13
* 3E8DFC  GAF926                                                         2013/11/29 12:37:03
* 3E9239  HG01A                                                          2013/11/29 07:18:12
   3E92DD  SHOCK1                                                         2013/11/29 08:21:27
   3E9DCE  SHOCK2                                                         2013/11/29 08:29:45
   3EA433  VADER2                                                         2013/11/29 08:22:43
   3F5271  GAF236                                                         2013/11/29 10:46:32
   3F5271  GAF236                                                         2013/11/29 12:49:18
   3F6006  GNY4531                                                        2013/11/29 09:25:30
* 3F7C8F  GAF107                                                         2013/11/29 09:50:33
   3F7DE5  VADER3                                                         2013/11/29 08:22:46
   3F885C  HG01B                                                          2013/11/29 07:14:58
* 3F9C7F  GAF106                                                         2013/11/29 12:32:58
* 3F9C7F        2013/11/29 21:52:43
   3FAF38  NOBLE1                                                         2013/11/29 10:30:13
Regards Ingo
mikek
Incorrect Route:
CAL054: NZAA-YBBN-RCTP (showing NZAA-NZAA-YBBN)
Mike
Unknowns from yesterday:
0D07BA (Mexico, no flight id, details already posted)
3C55AD (Germany, no flight id, nothing more)
405B71 (UK, no flight id, nothing more)
445566 (Austria, no flight id, again)
458DCA (Denmark, flight id: OYCNJ, OY-CNJ Aerospatiale ATR72-212 Kirk Aviation A/S 414 Source http://www.oy-reg.dk/register/6254.html and others)
48932B (Poland, no flight id, SP-EQL De Havilland Canada DHC-8-402Q Dash 8 EuroLot 4451 was posted with false HEX of 48932A, which is in the db)
503C2B (Lithuania, flight id: LYGVS, details posted by Niklas on Nov 29th)
A1C53D (USA, flight id: N213G, N213G Pilatus PC12/47E Private 1260 FAA: http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?NNumbertxt=213G )
AE067F (USA, no flight id, USA MIL)
MIL: 3E8DFC  GAF914
Regards and a nice Sunday!
Hi Jason,
As alluded to by Ingo, C034BA was only added to the database yesterday evening at 17:32 with the aircraft only coming on the Canadian register on 27/11 on lease from Thomson Airways for the winter.  As it was in the server at the time you noted it, if you had clicked on the aircraft the data would have populated for you.
Thanks Mike CAL54 corrected
John Racars
Good morning Alan,
FN NO ND NV || REMARKS NO ND NV
New:
BCS6849 EDDP LFPG ||
BCS768 EDDP EGLL ||
BEE1092 EHAM EGNX ||
BEE3MB EGBB EDDL ||
BEE432 EDDV EGBB ||
BER933P EDDL EDDH ||
DLH4TN EDDL LSGG ||
GWI6U EDDK EDDC ||
NAX9689 EFHK GCTS ||
TAY12G EBLG EGAA EGNX ||
TAY25N EBLG EGPH ||
TAY37B EBLG LEMD ||
TAY54 VHHH EBLG ||
TRA381M EHEH LIRN ||
WZZ6TJ LHBP EGGW ||
Correction(s):
MPH71 EHAM SBGR GCTS || i.s.o. EHAM SBKP GCTS
BLX217 EFHK GCTS || i.s.o. ESSA LGSA GCTS
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
Thanks again Ingo,
I will work my way through your listings.
Michel
Alan,
Not sure if you have this in the d/b already:
485064 ERJ190-100STD PH-EZY KLM Cityhopper cn 19000649.
Michel.
Yes thanks Michel, got it from the mode-s forum as it approached Amsterdam on delivery.
