Author Topic: Navdata.db.3 file  (Read 5738 times)
Wools
Navdata.db.3 file
« on: December 25, 2013, 07:40:27 PM »
Where can I find the latest Navdata.db3 file please. Have searched FAQ's etc.,
Peter
Re: Navdata.db.3 file
« Reply #1 on: December 25, 2013, 08:16:15 PM »
Peter,
We dont do Navdata files any longer for a couple of months at least.  We have a new Version 5 beta available on the forum which updates from within the software.  You can get it here http://www.airnavsystems.com/forum/index.php?topic=7959.msg99512#msg99512
Wools
« Reply #2 on: December 25, 2013, 11:02:54 PM »
Thanks followed the link and now running 5.00.062 but a/c have gone down from my previous 203,711 to 80,341.
Am I doing something wrong.
Peter
« Reply #3 on: December 25, 2013, 11:18:39 PM »
Have you run the updater in Database explorer to update to todays Navdata?  A new one is available each day, its around 210,000 aircraft records.
Wools
« Reply #4 on: December 26, 2013, 12:16:45 AM »
Yes have run it 3 times same result 80,341,
Peter
« Reply #5 on: December 26, 2013, 09:51:04 AM »
How many versions of RB do you have on your computer as it looks like it is going to one of the other versions.  Did you upgrade or a full install?
Also I presume you did a restart after installing the download
Wools
« Reply #6 on: December 26, 2013, 10:37:18 AM »
Did both without success as still had 80341
Then moved whole file from C/Programe files(X86) to just C and re-run the updater
and now showing a/c 210139.
However have also checked in my a file
Peter/AppData/local/Virtual file/Programes files (86) and have 2 files
AirNav Radar Box and AirNav Radar Box 2009 both with data files.
I guess I need to delete/move something but have not got a clue which to do. Any suggestions?
Peter
« Reply #7 on: December 26, 2013, 11:01:29 AM »
Peter,
Its hard to say at a distance what to delete but the good thing is that you moved away from the program files location to just c:\.
Even when you are on c:\ there are usually a few files in the X86 location for some reason thats beyond my knowledge.  I would think you would be able to delete the RB 2009 without any problems, i did a while ago.  Other than that my advice would be to leave well alone.  Now that you have got the updater pointing to the correct location you should have no further problems with it.
Wools
« Reply #8 on: December 26, 2013, 11:16:06 AM »
Many thanks for all your help, much appreciated.
Peter
Lou
« Reply #9 on: December 26, 2013, 03:21:52 PM »
Hi Alan would you be able to tell me if V 3.13 still updates, I`m reluctant to upgrade  to the new version as I will lose the updates,also I`m quite happy with V3.13. Regards Lou.
« Reply #10 on: December 26, 2013, 03:25:30 PM »
Lou,
No Navdata updates available expect for V5.  You will however still be able to use the populate function to update in previous versions.
