Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
AirNav Systems Forum
AirNav Radar Discussion
(Moderator:
How to add logos
« previous
next »
Print
Pages: [
1
Author
Topic: How to add logos (Read 5648 times)
AV61
Jr. Member
How to add logos
on:
December 30, 2013, 02:16:32 PM »
Can you please tell me how I can add a logo to individual aircraft
Nick
Logged
Moderator
Hero Member
Re: How to add logos
Reply #1 on:
December 30, 2013, 02:22:23 PM »
Name it the registration without and dashes such as GBUMP.bmp and place it in the logo folder.
There is every chance Rod has already done it so check out his logos at
http://www.rodbearden.com/RadarBox/Downloads.htm
and look to download and instal then into your log folder
Logged
Hero Member
Reply #2 on:
December 30, 2013, 02:23:59 PM »
In additiopn to Alan:
You can create your own logo: Size: 76x16pix to be saved as .bmp file in Logo Folder.
The filename is registration without dash/dashes EG: D-EITG logo shall be saved as DEITG.bmp
Note: Logo will only be shown if airframe is using its registration as flight id. If reg isn't used or not received no Logo will be shown. A tie-up with hex is currently not supported by ANRB software.
Just in case: An individual Silhouette (aiframe type) for each airframe is not supported by the software.
Logo folder is located:
your directory\
AirNav RadarBox\Data
HTH Ingo
Last Edit: December 30, 2013, 02:30:30 PM by neroon79
Logged
AV61
Jr. Member
Reply #3 on:
December 30, 2013, 02:30:08 PM »
Thanks you've just answered my next question
The tie up with the hex code you mentioned is
There a way I can use the hex code as the trigger for the
Logo or does it have to be the flight number only
Nick
Logged
AV61
Jr. Member
Reply #4 on:
December 30, 2013, 02:31:08 PM »
Sorry misread your post
There is no tie up with hex code
Nick
Logged
Hero Member
Reply #5 on:
December 30, 2013, 02:36:51 PM »
I wish that would be possible concidering the small private airframe in my area. In many cases I don't receive the flight id's due to edgy reception. In many cases (sail) planes aren't using flight ids at all. For theses airframes it would be great to have a hex tie-up. For the commercial airplanes it wouldn't make any sence...
Maybe one day...
Logged
Moderator
Hero Member
Reply #6 on:
December 30, 2013, 02:37:35 PM »
The logo is derived from the flight ID. The ICAO or IATA identifiers for airliners and for military aircraft etc, registration for business aircraft, private aircraft etc with registration as flight ID
Last Edit: December 30, 2013, 02:41:17 PM by Runway 31
Logged
Hero Member
Reply #7 on:
December 30, 2013, 02:38:58 PM »
No problem Nick. Sometimes the brain is just reading, that it wants te read...
Logged
Hero Member
Reply #8 on:
December 30, 2013, 02:41:46 PM »
does theat mean, although no flight id is reveived a business airframe will show a logo if there is one in the logo folder with its reg in the dashless style?
Logged
Hero Member
Reply #9 on:
December 30, 2013, 05:01:10 PM »
The full set of logo rules is here:
http://www.airnavsystems.com/forum/index.php?topic=6514.msg71413#msg71413
Logged
Moderator
Hero Member
Reply #10 on:
December 30, 2013, 06:12:45 PM »
No Ingo the logo is derived from the flight ID so no flight ID, no logo.
Last Edit: December 30, 2013, 06:19:05 PM by Runway 31
Logged
Hero Member
Reply #11 on:
December 30, 2013, 06:59:03 PM »
Thanks Alan. That's what I've had in my grey cells.
Logged
Print
Pages: [
1
« previous
next »
(Moderator:
How to add logos
