Author Topic: uPGRADES  (Read 7469 times)
vassylad
uPGRADES
« on: December 31, 2013, 08:14:16 AM »
Hello guys, I am currently running V3.13, how do I upgrade to V4.03 then onto V5.00
any help would be truly appreciated.
Michael
Re: uPGRADES
« Reply #1 on: December 31, 2013, 09:14:43 AM »
You dont need to go that route Michael.  Save your mylog and photo folders.  The uninstall RB and do the full install of the version which should be posted on the forum this morning, dont install 5.00.62 as it has expired..  Install to c:\Windows
Re: uPGRADES
« Reply #2 on: December 31, 2013, 09:20:54 AM »
V4.03 are basically the same, with the difference, that if you have purchased the 3D option you will have 3D functionality if you have installed V4.03. If you don't have 3D purchased then V4.03 and V3.13 will give you the same functions and options(=also called bugs).
Remember if you update to V5, your NavData.db will be encrypted after first use of V5
vassylad
Re: uPGRADES
« Reply #3 on: December 31, 2013, 10:29:03 AM »
So uninstall RB all together?
Re: uPGRADES
« Reply #4 on: December 31, 2013, 10:48:38 AM »
My opinion yes, as other than a larger download it would be quicker than doing various upgrades to get to the last one but it is up to you.
vassylad
Re: uPGRADES
« Reply #5 on: December 31, 2013, 11:05:33 AM »
Would that mean go back to the original 2009 CD and starting all over again then upgrading to V5.063?
Michael
Re: uPGRADES
« Reply #6 on: December 31, 2013, 11:13:00 AM »
The upgrade should work OK so why not give it a go first
However I meant just loading in 5.00.63 direct with no other version.  It has not been published by Airnav yet but here is the full install http://www.airnavsystems.com/download/ANRB/ANRB50063Setup.exe  You may also want to save your logos folder, silhouttes etc for use with the new version as it will load the same old stuff as the previous versions if you decide to go the full install route.  This method seems to work better for some users rather than upgrading hence why I suggested it but the upgrade route may be simpler for you.
vassylad
Re: uPGRADES
« Reply #7 on: December 31, 2013, 11:15:07 AM »
Thanks Runway but alas that link is dead
Michael
Re: uPGRADES
« Reply #8 on: December 31, 2013, 11:21:29 AM »
Just remove the last control letter and it works: http://www.airnavsystems.com/download/ANRB/ANRB50063Setup.exe
Re: uPGRADES
« Reply #9 on: December 31, 2013, 11:37:10 AM »
Sorry Michael, Windows added that junk from me using the space key.  As Ingo states removing the junk after exe lets it work
anorak
Re: uPGRADES
« Reply #10 on: December 31, 2013, 12:45:51 PM »
Down loaded the upgrade to.063 but the hardware is not connecting now, all was working fine last night before the time ex hit. Will try closing down and rebooting.
Dave.
Dave. Exmoor, North Devon.
vassylad
Re: uPGRADES
« Reply #11 on: December 31, 2013, 06:50:52 PM »
To each and everyone of you who replied to my question thank you so so much, all is well and up and running.
Happy new year guys
All the best for 2014
Michael
Re: uPGRADES
« Reply #12 on: December 31, 2013, 06:51:34 PM »
Cheers Michael, all the best to you and your.
Re: uPGRADES
« Reply #13 on: December 31, 2013, 07:06:23 PM »
Happy 2014 to you and yours!
Fair winds and shallow seas!
Re: uPGRADES
« Reply #14 on: December 31, 2013, 07:28:02 PM »
May all your dreans for the coming year come true and good health to all.
