AirNav RadarBox 5.00.65 - Download Available
Started by AirNav Development, January 07, 2014, 02:15:59 PM
Hi Alan, I'vealready done that, but, thanks for the suggestion!
Hi Jon
Are you using the "Pin Map with Active Flight" button?
Question:
I haven't used ACARS for many years, but I notice that the ACARS tab is not there any more. Does that mean that RadarBox has stoppped integrating ACARS?
shouriken
I have been able to reproduce the issue reported in reply #132 in the 53 beta topic:
- open "My log/Grids" window first time after starting anrb.exe
- resize the upper/lower size of the grids.
The snapshots mylog-11-01 and mylog-11-02 are from today.
Liviu
A.net JetPhotos.Net
RadarBox
Noted Liviu will pass on to the Developer
Hi Rod, and Alan,
No, I haven't tried pinning the map as Rod suggests in Reply #106, so will give that a go. Thanks for the suggestion Rod.
Jonathan.G
Hello, is this a bug from the 5.00.65 ? some aircraft do not have the "label" :/
#114
Jonathan,
What happens if when you zoom in.  Limits are placed on the number of lables that are displayed at anyone time to ensure the screen is not overeloaded with information which would make it unreadable.  Zooming in will reduce the number of aircraft being displayed and enable further lables to be shown.
Jonathan.G
Hi Alan
On the subject of column sorting, I notice that sorting in the Groundspeed column is done in alpabetic order, not numeric order. All the other numeric colums are fine, but Groundspeed sorting goes wrong, as in this screenshot of the column sorted in descending order, where the fastest planes should be at the top.
#117
Will have it checked out.  It will be corrected by the addtion of a leading zero in a future update.
puddy
Quote from: Runway 31
Thanks Neil,
I would think that there are a good number of users on Windows 8 now and its the first I have heard of that one, no other Windows 8 user has advised of that problem.  I can think of no reason why you need to do no more than the usual restart of the software to complete the Navdata instalation process and start up the software.
Yes you have ME
if you're talking about windows 8.1?
I also told Airnav twice on how the menu system differs between windows 8 and windows 8.1
Runway 31 stated my computer skills are so  low and he stated no one else has these problems in windows 8.1
A way from home but if you need the setting/work round  I post them today. I have gone back to 403 because its not been fixed
ps  Please note if you are running windows 8.1 you may find your network flights time out after 5 minutes and then disappear.
