AirNav RadarBox 5.00.65 - Download Available
Started by AirNav Development, January 07, 2014, 02:15:59 PM
Ah well, that will solve that problem for now, but it has highlighted that logo problem, so it's still worth passing on to Dev, but it's a rare problem.
#76
Let me get it right Rod, you had the ANX logo on your folder and when you picked up the aircraft today on its return journey displaying a flight ID of ANX207 it didnt show.  Is that correct, I'm confused?  Are you stating that while it didnt show the logo from the flight ID ANX, it would have from the registration ANX-207 if that had been the correct in the database
diddyboy
Hi Alan
Hope you can help, I have just got a new Laptop with Windows 8 as my previous one crashed just before Christmas. and lost everything. (hence the lack of requests) I have tried installing full download of 5.00.65. I have a red block showing that hardware flights is not connected. The box is ticked and I have unplug and reinserted the USB. I am unsure if I have downloaded it correctly as I noticed on the download there was in brackets (x86), do I have to uninstall and download again and take these out, I have also used the same activation code/ password that is on the disc. would it be easier to load this first then upgrade? Please help
Neil
diddyboy
diddyboy
Hi Alan
for some reason it will not let me Unzip the file. My brain is not working as I have been travelling since yesterday morning, so I am doing something wrong.
Comes up as open only or save or save as
Neil
Neil,
Save it first then right click and unzip the saved file.
diddyboy
Still nothing will try again in the morning
\regards
Neil
Neil,
Once unzipped you will require to go to Device and Printers and find the Radarbox, right click Properties/Change  Settings/Driver/Update Driver and then when asked direct it to where you unzipped the drivers to and it should then instal them.  It may be slightly different as I have Windows 7 so may not have it correctly stated.
diddyboy
Hi Alan/All
I have tried everything after the download of the full version, but to no avail. could some kind soul who has windows 8 please give a step by step guide so that I can get rb24 working. I have downloaded the drives (I think) it and saved it onto desktop but when I try to add it comes back with windows encountered a problem installing you device.
Sorry for being a pain.
Kind Regards
a disheartened Neil
Neil,
Lets start at the beginning. As you already have the file on your computer I suggest the following
Click on http://www.airnavsystems.com/download/ANRB/ANRB50065Setup.exe  you will get a dialogue box asking if you want to Run or Save the file.  Click on Run, this will download the file and once downloaded will ask are you sure you want to Run the file, click Run and the installation dialogue box will open up.  Remove the two end characters from the link which windows added.
Accept the agreement etc and install to path C:\AirNav Systems\AirNav RadarBox and that should be it.
Connect you USB cable.
Then go to the Devices and Printers and install the Windows 8 drivers as advised previously and RB should then work OK once started.
If you still cant get it to work I would suggest you email support or if you are in the UK email me and I will give you my phone number and talk you through the process
diddyboy
Hi Alan
Still having difficulty as it is saying the drivers are corrupt. I will email support to see what they say.
Many thanks for all your help so far.
Neil
chrisonmas
Installed the update, but during start-up, in the dialogue box it says RB 1 - not found, RB 2 - not found.
Any ideas.
Chris
RB1 is the current box, RB2 is something else.
