Author Topic: AirNav RadarBox 5.00.65 - Download Available  (Read 63567 times)
BlinkNFG
Re: AirNav RadarBox 5.00.65 - Download Available
« Reply #30 on: January 13, 2014, 09:24:27 PM »
Thanks Alan
    • Rod's RadarBox Downloads
« Reply #31 on: January 14, 2014, 02:57:44 PM »
A couple of typos on the Preferences 3D View screen - Date instead of Data, and Feets instead of Feet
« Reply #32 on: January 14, 2014, 03:05:34 PM »
Thanks Rod, developer advised.
MIKE.UTD
« Reply #33 on: January 14, 2014, 06:56:17 PM »
In relation to the fonts sorry but no, I see you can do this to get the 3 different styles but all I want to do is to get the height readings decending downwards and this is the only way to click on the altitude header to do this.
Mike.
« Reply #34 on: January 14, 2014, 07:28:31 PM »
Mike, click on Altitude first time and you get lowest to highest going down the screen.  Click again and you get highest to lowest going down the screen.  Click on it again and it goes back to original.  To highlight you have it set it is Bolded or Bolded with italics
« Reply #35 on: January 14, 2014, 07:29:56 PM »
This may have been asked before but there are an awful lot of posts to plough through so if anyone can help.......
Everything running OK since upgrade with the exception of a number of blanks appearing in the "aircraft" column. For example basic flights like EIN 17R and EZY43HP  have OK pictures with OK details of routes and aircraft  - airbus 320-214 & A319 respectively - but nevertheless there are blank spaces in the Aircraft column.
Any ideas please?
« Reply #36 on: January 14, 2014, 07:38:26 PM »
Further to the above it is both Registration and Aircraft that are missing from some of the flights.
« Reply #37 on: January 14, 2014, 08:03:00 PM »
I havent heard of this one Bratters.  Which version did you upgrade from?
« Reply #38 on: January 14, 2014, 08:12:54 PM »
I moved my existing 3.13 to an an external drive for emergency back up then loaded my original Airnav 2009 and subsequently downloaded the V5 upgrade. No problems at all except as above.
As a matter of interest, if I revert to 3.13 will I still get the daily data download or do I have to persist with V.5?
Thanks for your response Alan.
« Reply #39 on: January 14, 2014, 08:28:31 PM »
V5 only Bratters for the data updates.
I dont know if the upgrade works for anything other than 4.03 up.
For 3.13 my suggestion would be for the full install instead of an upgrade.
« Reply #40 on: January 14, 2014, 08:35:33 PM »
Thanks Alan. I initially tried a full install but it wasn't right and the program ran so slowly as to be almost intermittent. Time stood still!
I've an outdated and underpowered pc which probably doesn't help although 3.13 still bowls along merrily.
I'll sleep on it.
« Reply #41 on: January 14, 2014, 10:28:54 PM »
Alan - the problem seems to have resolved itself and all columns are now populated. It may be just due to lack of resources and slow running but whatever the reason, we are back in business.
This would also indicate that you can in fact upgrade the original version of RB!!
« Reply #42 on: January 14, 2014, 10:46:33 PM »
Good to know that Bratters, I suppose that I shouldnt be surprised as 3.13 is only 4.03 without the 3D and good to know its going OK
« Reply #43 on: January 17, 2014, 02:09:50 PM »
Oddity: the software is refusing to download photos for G-EZIH. The links in the database are both OK, but I'm constantly getting "Photo not available" when clicking on it on the grid, and the photos aren't in the photos folder.
« Reply #44 on: January 17, 2014, 04:46:07 PM »
Hi Rod,
I have checked the links and they appear OK.  the photos are not on my main computer but are on my laptop.  I have deleted the links on the server and reapplied them to see if it makes a difference.
