Started by orkney, January 27, 2014, 05:29:14 PM
0 Members and 8 Guests are viewing this topic.
Michel
Alan,
TRA623V EHAM-LEPA
Michel.
Hi Alan
Not populating:
43C6CB currently on the ground, probably at Warton
Hi Rod,
Its an unknown Typhoon at this time
Alan,
Getting a bit sick of this lot !
EVE1518 : LEVC-GCTS
Thanks Ian,
A new one for you to look out for just off Toulouse on delivery is-
3444CC EC-MAN Airbus A320-214 c/n 6079 Vueling Airlines
M
ELL683 EETN ESSA
VKG941 EFHK LCLK
NWS1747 ULLI DTMB
NWS1748 DTMB ULLI
CYYZGUY
Goodmorning Alan
Mode-s C0323E
Flight ID- MALATR72
No other fields populating.  I see him pop up now and then early in the morning. then he dissappears..
By the looks of it, I think it is a Morningstar Air Express..
Jason
40" LED Monitor
40" LED Monitor
Hi Jason,
It is indeed Morningstar
C0323E C-FTAR Aerospatiale ATR 72-202F c/n 217 FedEx Feeder/Morningstar Air Express
diddyboy
Hi Alan
Unknowns from the Sandpit so far today:
* 7629C1  PAAF734                                                   2014/04/29 10:25:45
* 83B4C2        2014/04/29 12:12:46
* 83B4C2        2014/04/29 15:22:14
Neil
Hi Neil,
7629C1 is an unknown 4 engine heavy prop which overflew the pit.
I also don't have anything on the Indian hex.
Evening. It's been a while. But here are the unknowns from yesterday:
* 29C8D1        2014/04/28 11:22:19
* 3C6129        2014/04/28 08:05:44
   3CDA81  DCKAZ                                                          2014/04/28 10:46:29
   3E80B1        2014/04/28 17:01:46
   3E8107        2014/04/28 08:18:08
   3E8107        2014/04/28 12:23:09
* 3E9448  GAF320                                                         2014/04/28 10:19:57
* 3EA77E        2014/04/28 07:46:03
* 3EB7D1        2014/04/28 17:17:39
* 3F4F6D  GAF807                                                         2014/04/28 09:04:37
* 3F4F6D  GAF807                                                         2014/04/28 13:01:52
* 3F6124  GAF771   EDDK-EGWU                                             2014/04/28 18:58:10
   3F93D4        2014/04/28 06:27:43
* 3F9489  HG01A                                                          2014/04/28 10:14:51
* 3F9EBE        2014/04/28 13:41:12
* 3FB008  GAF163                                                         2014/04/28 13:43:29
   3FF278  DMGSP                                                          2014/04/28 16:11:45
* 44D071        2014/04/28 11:53:22
* 5CA73E        2014/04/28 19:05:29
   730000        2014/04/28 13:03:23
* A40457        2014/04/28 22:02:21
* AE4F17        2014/04/28 13:59:44
Ragards Ingo
Hi Ingo,
As you stated its been a while so nice to hear from you again.
29C8D1 miscode unknown to me
3C6129 not current
3CDA81 D-CKAZ Beech B300 King Air 350 c/n FL-216
3FF278 D-MGSP unknown to me
44D071 unknown not allocated
5CA73E unknown no country allocation
730000 unknown Iranian code
A40457 not assigned
AE4F17 an unknown C17 which fits the sequence and may be 10-0223 recoded but needing confirmed.
CYYZGUY
#1529
Not too sure why, but I just got a slew of non populated routes showing up...
SWG602
DLH443
DAL8844
AAL415
ACA461
ACA1125
ACA085
AAL341
VRD174
PIA790
UPS2314
Odd for me to get so many at once.. Can you check them out Alan?
Jason
40" LED Monitor
40" LED Monitor
