Started by orkney, January 27, 2014, 05:29:14 PM
Morning Alan,
BEE175A : EGHI-LEAL
VLG8252 : LFPO-LEAL
As to EXS33N, I didn't add in the route. I have gone into routes this morning via d/b explorer and nothing in showing. Having said that, I haven't done a d/b update.
Cheers Ian,
Re EXS33N, With your outdoor antenna its possible that you already had it on your screen when I added it in, therefore it wouldn't autopopulate.
Alan,
I have just performed a d/b update and EXS33N is now appearing in the route table.
Thanks,
flygfantast
Not populating:
4784AF no c/s
4B0D7B c/s HBFCT
Niklas
Cable: Ecoflex-10 (10m+1m)
Xon
488195 SP-AMZ R44 c/n 13481
Afternoon, one addition to yesterdays unknowns:
* 3FAC03        2014/05/06 16:26:25
Hasn't populated: * 3E8BCC  NOBLE2                                                         2014/05/06 07:26:01
Regards Ingo
Unknowns from today:
* 00B7DE        2014/05/07 13:20:31
* 39A0F0        2014/05/07 13:44:55
   3C48E9        2014/05/07 12:41:23
* 3C6002        2014/05/07 14:51:48
   3C6301        2014/05/07 05:01:12
* 3D065C        2014/05/07 09:00:28
* 3D065C        2014/05/07 12:33:03
* 3D7646  DFRAS                                                          2014/05/07 09:23:32
* 3D7646  DFRAS                                                          2014/05/07 14:00:19
* 3E806F        2014/05/07 07:12:45
* 3E806F  GAF926                                                         2014/05/07 10:44:08
* 3E8806  TA62                                                           2014/05/07 07:03:10
* 3E8806  GAF640                                                         2014/05/07 09:04:31
* 3E8806  GAF640                                                         2014/05/07 09:51:03
* 3E8C7F  GAF191                                                         2014/05/07 08:15:02
* 3E8C7F  GAF191                                                         2014/05/07 09:11:43
* 3E8C7F        2014/05/07 11:28:13
* 3E903C  SMASH2                                                         2014/05/07 07:35:30
* 3E903C  HAMMER1                                                        2014/05/07 13:06:22
* 3EB7DE  TIGER01                                                        2014/05/07 13:12:31
* 3EB7DE  TIGER01                                                        2014/05/07 14:16:14
* 3F68AC  GAF067                                                         2014/05/07 07:31:55
* 3F6B9F  GHOST2                                                         2014/05/07 08:43:24
* 3F6CB2  GHOST1                                                         2014/05/07 08:43:34
* 3F6CB2  JUSTIS                                                         2014/05/07 15:18:25
* 3FAE58        2014/05/07 13:47:38
* 40042C        2014/05/07 10:00:23
* 400FD6        2014/05/07 05:07:18
   401080        2014/05/07 12:41:21
* 43E91D        2014/05/07 11:16:07
   484182        2014/05/07 12:01:24
* 4D6F20        2014/05/07 10:55:21
* A04441        2014/05/07 12:53:03
* AC2D36        2014/05/07 08:37:15
Regards Ingo
Hi Niklas,
4784AF LN-OVE Eurocopter AS350 B3 Ecureuil c/n 7605 Scandinavian Helicopter Group/Fonnafly
4B0D7B c/s HBFCT decodes to HB-FCT which was a PC6T of Air Glacier but checking the Swiss register shows that it is no longer allocated.  I am unaware whether it is the old one miscoding its old ID or a new allocation but either way it is not showing on the register.
Hi Ingo,
3FAC03 was 88+03 but my d/b shows it was cancelled in 2011
I must have missed the other one but its in now.  Going out now and will get the others when I return.
flygfantast
Thanks. A little typo on the airline on LN-OVE, "Scansinavian...." instead of "Scandinavian..." :-)
Niklas
Michel
Alan,
TRA761 EHAM-LTFG
TRA1755 EHAM-LTAI
TFL749 EHAM-LTAI
TRA145 EHAM-LTFG
TRA1325 EHAM-LGPZ
TRA741 EHAM-LTFG
TRA1797 EHAM-LTBS
TFL791 EHAM-LTBJ iso EHAM-LTBJ-LTFE
TRA305 EHAM-LTAI iso EHAM-LGRP
TRA575 EHAM-LTAI iso LTAI-EHEH-EHRD
Michel.
Ingo,
00B7DE is a South African Microlight, cant see it being here
39A0F0 not allocated
3C48E9 decodes to D-ABGI unknown to me
3C6002 doesn't decode
3C6301decodes to D-AHXA unknown to me
3D065C decodes to D-EAQU unknown to me
3D7646 D-FRAS SOCATA TBM 900 C/N unknown, not the TBM8 which previously held the registration
40042C not current
400FD6 not current
401080 not current
43E91D not current
484182 not allocated
4D6F20 unknown to me
A04441 not assigned by FAA
AC2D36 not assigned by FAA
Thanks Niklas,  I could have sworn that I noted and changed it before sending it to the d/b.  Its done now.
