Started by orkney, January 27, 2014, 05:29:14 PM
Morning Alan,
Not sure the reason for this invasion but had I known in advance I would have been at the airport :
ENT525 : ESGG-LEAL
ENT517 : EFHK-LEAL
ENT519 : ESSA-LEAL
Cheers Ian,
I will need to get in the habit of looking up the days movements.
#1637
Afternoon Alan,
This came onto 'My Flights'. Non ADSB :
30003A No further information but according to 'Airframes' refers to MD82 I-DATE c/n 53217 of Alitalia which was wfu/stored 20/10/2012 ?
Clicking on the Mode S yielded nothing.
Addition : It's now showing a flight ID of 'AZ1200'.
Flieger_NDS
Quote from: neroon79 on April 09, 2014, 04:36:08 PM
* 683202  TIE743V                                                        2014/04/08 16:40:26
Came up again today. It is UP-K3503, AirControl Kazachstan, FL-322. Previously OK-VTK from Time Air (TIE), someone forgot to remove the old flight number from the transponder.
#1639
Hi Ian,
I-DATE became N982FA and was with FLTS Aviation in Miami for freighter conversion.  Skyliner is showing it as on delivery 07-08may14 MIA-SMA-TUN and is heading for Sri Lanka were it will become 4R-*** in due course.  It is therefore carrying the N registration but is using its old hex instead of its allocated ADB310.
Many thanks again Flieger_NDS
Some additions to yesterdays unknwons:
* 39A0F0  FHIHQ                                                          2014/05/07 15:55:37
   3C5EFD        2014/05/07 19:10:22
Regards Ingo
Hi Ingo,
39A0F0 F-HIHQ Diamond DA20-C1 Eclipse c/n 20205 Aero Technique Assistance
Nothing on 3C5EFD, it doesn't decode.
Unknowns from today:
   0003C9        2014/05/08 08:35:15
* 186001        2014/05/08 11:34:35
   3D31D6        2014/05/08 05:11:25
* 3E92F2  TA145                                                          2014/05/08 08:48:31
* 3EA2D3  GHOST3                                                         2014/05/08 09:09:16
* 3EA5F3  BURNER1                                                        2014/05/08 13:32:07
* 3EA895  PIRAT                                                          2014/05/08 07:50:37
* 3EB6CB        2014/05/08 08:39:26
* 3EBDC3  GAF207                                                         2014/05/08 06:05:07
* 3EBDC3  GAF207                                                         2014/05/08 08:32:52
* 3EBDC3  GAF207                                                         2014/05/08 12:34:14
* 3EBDC3  GAF207                                                         2014/05/08 14:38:46
* 3F5891  RAVEN                                                          2014/05/08 05:53:24
* 3F5891  RAVEN                                                          2014/05/08 13:34:46
* 3F6796  RHINO1                                                         2014/05/08 09:02:42
* 3F7B35        2014/05/08 13:14:02
* 3F8193        2014/05/08 09:36:53
* 3F8F26  NOBLE01                                                        2014/05/08 08:28:13
* 3F93E0        2014/05/08 09:19:22
* 3FB955  HG01A                                                          2014/05/08 08:05:18
* 3FB955        2014/05/08 12:17:59
* 45AA73  OYJSW                                                          2014/05/08 07:17:37
* 4BAA57        2014/05/08 13:47:43
* 780C4A  QDA9956                                                        2014/05/08 14:36:43
   EA0000        2014/05/08 08:31:22
Regards Ingo
Hi again Ingo,
0003C9 miscode unknown to me
186001 miscode unknown to me
3D31D6 decodes to D-ERCW unknown to me
45AA73  OYJSW decodes to  OY-JSS which is not allocated OY-JSW is allocated 45AA77 so is presumably miscoding
4BAA57 decodes to TC-JRW not allocated
780C4A B-9956 Airbus A320-214 C/N 6102 Qingdao Airlines
EA0000 miscode unknown to me
45AA73  OYJSW I did some further investigation. It seems that this entry was caused by some bad/corrupted data packets received. I've found 45AA77 OYJSW with much more messages received in my list at two different times. Second time matches up with reception time of hex 45AA73 OYJSW.
Thanks for the info Ingo
Evening Alan,
Arriving now at LEAL from EHAM :
4840FE not populating but should be PH-HZA B737-8K2 c/n 28373 of Transavia.
Out of Recife for Sal on the second leg of its delivery flight to Belavia is 510080 EW-400PO Embraer 190-200LR-195LR c/n 19000668
