Started by orkney, January 27, 2014, 05:29:14 PM
Cheers Ian, thank goodness for a good pair of bino's.  Did you get the email I sent you with a couple of shots from yesterday
Alan,
Just had a look at them. Truly superb.
Thanks for that,
spanman
Can anyone help me please with an issue I am getting and apologies if it has been covered in any previous notes.
The UK aircraft that have been re-registered on the British register i.e a percentage of the Monarch and Jet 2 fleet keep reverting back to their original registration no matter how many times I update them. Am I missing something or can someone point me in the right direction please?
                                    Mark
Flybe Crew on the Dash 8 Q400  Embraer 175
and Embraer 195
Michel
Alan,
CND712 LGRP-EHAM iso LGIR-LGRP-EHAM
Michel.
F-WWCH (380B1A) is in db as: Airbus Testreg. various A340 airframes. Reagarding the fact that the A340 isn't build anymore, this should be changed to A330, as this reg was used for A330s recently.
Regards Ingo
Correct Ingo, was used 6 times by A340's but the last 3 times by various A330 models
Mark,
Can you give an example of one of your hex codes that reverts back to its previous registration please.  As the database is up to date for Monarch and Jet2 fleets as far as I am aware, I am at a loss as to how they can revert to a registration which isn't in the database.
spanman
             one example is G-GDFK Jet2 B733 which comes up on the list as G-STRE .All the Monarch A321's that are ex BMI revert back to the BMI registrations and operator ,and only change when you click on the aircraft which then automatically updates to the current and correct reg/operator.
and Embraer 195
#1808
Mark,
Can you confirm that you are not using the database updates for these and are trying to update manually using the original database.  4406EB G-GDFK was registered 16/3/2012 and has been in the database since 20/3/2012.
spanman
            I have  just gone into database updates and downloaded the latest. Restarted the application as stated and first thing I see on my screen is G-SJMC MYTravel Airways which is obviously now TCX and G-TCCA. Click on it and it updates to the correct details but doesnt retain it !
Very odd !!
and Embraer 195
Mark,
I would suggest that you have more than one instance of Radarbox on your computer and the wrong older Navdata is being used, G-SJMC isn't in the database and neither is Mytravel so looks like you are looking at the original database from one of the instances on your computer through another newer instance.
My suggestion would be to delete all versions of RB from your computer and start again by installing V5.00.65 then upgrading to V5.00.71.  If you do this save your mylog, photo folder, logos, silhouettes etc that you want to keep and reuse them in the new version.
spanman
Thanks Alan I 'll do that. Cheers for your help,
        Mark
and Embraer 195
Afternoon, the unknowns from Sunday:
   3D0E18  DEDOY                                                          2014/05/18 09:33:00
   3D0E18        2014/05/18 11:27:13
* 3D1031  DEEJP                                                          2014/05/18 09:24:49
   401080        2014/05/18 12:20:16
   473400        2014/05/18 08:31:17
* 48D40B        2014/05/18 16:48:58
* 4A5CB5        2014/05/18 10:42:53
   4CA2D2        2014/05/18 17:14:44
   4CA991        2014/05/18 10:01:47
* 670840        2014/05/18 08:03:08
* 78A001        2014/05/18 11:55:25
* 8963F8        2014/05/18 11:44:08
Regards Ingo
Michel
Alan,
TRA716Z LGZA-EHAM
TRA612 LGKF-EHAM iso LGKR-EHAM
CND192 LTBJ-EHAM iso LTBS-EHAM
Michel.
Hi Ingo,
3D0E18 decodes to D-EDOY previous was an AC11 which was substantially damaged in 2006 don't know if same one
3D1031 D-EEJP c/n F150-0175 Reims F150G
401080 not current
473400 unknown to me
48D40B doesn't decode
4A5CB5 decodes to YR-WEU unknown to me
4CA2D2  not current
4CA991 doesn't decode
670840 no country allocation
78A001 doesn't decode
8963F8 unknown at this time, being queried
