Started by orkney, January 27, 2014, 05:29:14 PM
about D-EDOY: is this the one that was substantially damaged in 2006? http://www.abpic.co.uk/photo/1452918/
Yes Ingo, its the same one and it is looking very nice as well.
Many thanks
paul tricker
Info from the boys in the sandpit minus X
702059  S2-AHK  B777  Biman Bangladesh Airlines.  Just need the missing details for it now
Paul
#1818
Hi Paul,
Its one of 2 on lease from Egyptair.  The other is S2-AHL which is 32630/368 so S2-AHK is 32629/362 ex SU-GBX
paul tricker
Hi Alan
Thanks for the extra info on S2-AHK.
7CF98E  I-RAII   went over Southern England earlier, 2nd C27J for the Australian AF??
Paul
Hi Paul,
Saw your post on mode-s, its  A34-002 but don't have its c/n  yet.
Can you find out from the sandpit crew if they know the ID of 8963F8 c/s RJD301 of Rotana Jet
paul tricker
Nothing yet on 8963F8, it landed at AZI, Bateen, in the dark last night
Will advise when further known
Paul
paul tricker
All the pictures on the web of S2-AHL give the c/n of  32629 & not 32630.
Getting confused now!
Paul
#1824
Hi Paul,
I took the c/n info for S2-AHL from AvDb which gives it as 32630/368 added to the databse 20/3/2014
In addition CH Aviation from 31st march details the following which backs this up
Biman Bangladesh Airlines (BG, Dhaka) has taken delivery of its first of two B777-200(ER)s on lease from EgyptAir (MS, Cairo Int'l). As previously reported, the twinjets are SU-GBY (msn 32630) and SU-BGX (msn 32629) of which the former, now registered as S2-AHL, has now arrived in Dhaka while the latter is still in Cairo Int'l awaiting its ferry flight.
Afternoon Alan,
RAM250 : GMMN-OEJN
NOS9431 : LLBG-LEMD
The 2 French aircraft which are now being operated by Vueling are both ex Air Corsica aircraft A320-214's. They are F-HDMF c/n 4463 and F-HDGK c/n 4478. They are both in Vueling colours but not been identified if now Spanish registered.
Cheers Ian,
I see from the Murcia departures that MON123 leaves for JFK at 1300 and there is a CSA A139 in and out this afternoon
paul tricker
Ah, Ok Alan thanks
I'll go with you & CH Aviation
Paul
Alan,
That Monarch flight is very unusual. It must be doing a one-off charter for somebody. It's the first time I have heard of flights going to JFK from Murcia. Also the use of a common flight ID of just MON123. Interesting to see what comes on AN at dep 1300.
Alan,
Just been back on the AENA site and that departure from Murcia to JFK is no longer showing. Very strange !
As you say, it was definitely there.
