Started by orkney, January 27, 2014, 05:29:14 PM
Many thanks Rotorspot, that one escaped my attention.
Michel
Alan,
Something new, German I guess:
3E99AC  GAFE12A
Michel.
Its a German military tactical code Michel
Up on its first flight using its new ID is 43C6FA ZZ337 Airbus Voyager KC3 c/n 1390 UK - Air Force.  Ober the Bristol Channel as TTN42 ex G-VGYH cancelled yesterday
Northern Watch
Hi Alan
Just had this that did not populate. Believe this to be a Tucano as another one has been flying around using c/s LOP405 which did populate:
43C674 / c/s LOP406
Keith
Hi Keitkm
43C674 is thought to be ZF169 but has not actually been positively tied up, depending on where you look you may actually get another couple of serials but nothing confirmed so far.  My d/b gives ZF169 as last noted WFU and stored at Linton in 2012.
shouriken
3003F1 - I-MLDT: the AT field in the db should be F50.
Liviu
A.net JetPhotos.Net
RadarBox
Afternoon Alan,
We'll just have to keep doing it this way I'm afraid :
EVE1328 : LEAL-LEBB
Blueboy
Hi Alan, a question for you - landed at Glasgow last night was Cessna P210 N995RK  c/n 21000846
however my RB had this as HEX 3D0F46 D-EEAO which is a PZL 104 Wilga according to Database.
On checking GAS, this shows D-EEAO as Cessna P210  c/n 21000846.
J.D at confused.com
Evening, the unknowns from yesterday:
* 3442C7        2014/02/26 15:30:15
* 385CE5        2014/02/26 09:38:10
   3C0CA5  TUI7YB   EDDV-GCTS                                             2014/02/26 03:42:51
* 3C48FB        2014/02/26 08:49:12
   3C5454        2014/02/26 18:48:55
* 3D0F46        2014/02/26 18:04:49
   3D31B0        2014/02/26 12:16:19
* 3D8F31  DGAMB                                                          2014/02/26 08:51:48
* 3D8F31  DGAMB                                                          2014/02/26 11:37:48
   3E8B0E  BU63                                                           2014/02/26 19:30:57
   3E8C8D  SMASH4                                                         2014/02/26 13:31:24
   3E8F00        2014/02/26 07:20:52
   3E93FF  GAF171                                                         2014/02/26 09:18:34
   3E967F  KNIGHT                                                         2014/02/26 09:41:50
   3E967F        2014/02/26 11:31:58
   3E967F        2014/02/26 16:25:20
   3E9ADE  GAF771   EDDK-EGWU                                             2014/02/26 12:35:28
   3E9EDB        2014/02/26 13:11:25
* 3EA5C2  NOBLE1                                                         2014/02/26 12:49:32
* 3EA616        2014/02/26 14:45:53
* 3EA63F  EIFEL                                                          2014/02/26 09:55:06
* 3EB190  SMASH1                                                         2014/02/26 13:28:35
* 3EB640        2014/02/26 14:43:04
   3EBF1B  HG01B                                                          2014/02/26 07:15:32
* 3F64E4  BU62                                                           2014/02/26 19:14:43
   3F6926  NOBLE2                                                         2014/02/26 12:49:50
   3F6926        2014/02/26 17:43:47
   3F81CC  SPOOK                                                          2014/02/26 13:48:22
   3F826A  SPARK                                                          2014/02/26 12:19:43
* 3F85A5        2014/02/26 14:35:06
* 3F85A5        2014/02/26 15:21:53
   3F8D63  GAF139                                                         2014/02/26 13:16:23
   3F8FA9        2014/02/26 18:01:12
   3FA6BB  GAF121                                                         2014/02/26 08:11:34
   3FA6BB  TA36                                                           2014/02/26 17:03:14
   3FB6DD  GAFE13T                                                        2014/02/26 09:43:22
   3FB6DD        2014/02/26 18:58:45
   3FB98B        2014/02/26 08:07:47
   3FB98B        2014/02/26 14:54:39
* 3FBB0D  GAF997                                                         2014/02/26 18:13:31
   3FF105        2014/02/26 12:26:39
   445566        2014/02/26 06:59:25
   445566        2014/02/26 07:43:27
   445566        2014/02/26 17:58:00
   45AC29        2014/02/26 20:05:25
   45C94B  SAS1587  EKCH-ELLX                                             2014/02/26 07:22:58
   45C94B  SAS1588  ELLX-EKCH                                             2014/02/26 09:24:22
   45C94B        2014/02/26 11:55:15
   45C94B        2014/02/26 13:52:36
   45C94B        2014/02/26 19:13:06
   45C94B        2014/02/26 20:19:21
   48ADA6        2014/02/26 11:34:20
   4D02C4        2014/02/26 09:01:32
* 7000CA        2014/02/26 12:30:02
* 8003CF        2014/02/26 10:22:31
* B803CA        2014/02/26 12:38:05
   C00000        2014/02/26 12:33:50
Regards Ingo
PS let's see if the populate function is working now.
Tuesday:
* 0000CA        2014/02/25 14:09:42
* 2C642D        2014/02/25 16:09:52
   3C0CA5  TUI53Y   GCFV-EDDV                                             2014/02/25 00:00:00
   3C0CA5  TUI6954  EDDV-HEGN                                             2014/02/25 05:10:01
   3C0CA5  TUI6955  HEGN-EDDV                                             2014/02/25 14:53:31
   3C4843        2014/02/25 14:20:50
   3C49AD        2014/02/25 07:43:39
   3C6649        2014/02/25 17:32:31
   3D2D66  DEPLE                                                          2014/02/25 13:20:22
   3D2D66  DEPLE                                                          2014/02/25 14:36:18
* 3D31B0  DERBK                                                          2014/02/25 11:10:48
* 3D3A04  DEUFK                                                          2014/02/25 11:39:38
* 3D5C3C        2014/02/25 09:06:49
* 3D5C3C        2014/02/25 16:19:27
   3E8F00        2014/02/25 14:23:07
   3E8F00        2014/02/25 14:58:46
   3E8F5C  FILTER                                                         2014/02/25 14:42:23
   3E93FF  GAF712                                                         2014/02/25 07:25:10
   3E967F  KNIGHT                                                         2014/02/25 09:13:02
* 3E9EDB  HG01B                                                          2014/02/25 13:14:34
   3EAC3F  GHOST                                                          2014/02/25 09:21:27
   3EAC3F  GHOST                                                          2014/02/25 11:19:24
   3EAC3F        2014/02/25 14:02:07
   3EAC3F  NITRO1                                                         2014/02/25 15:26:14
* 3F649C        2014/02/25 09:24:45
* 3F890B        2014/02/25 11:27:53
* 3F890F  NOBLE                                                          2014/02/25 11:16:17
   3F8DA7  NOBLE2                                                         2014/02/25 17:35:47
   3F8FA9  NOBLE1                                                         2014/02/25 17:42:53
   3F9191        2014/02/25 09:20:51
   3F9248  GAF757T                                                        2014/02/25 09:38:27
   3F9248  GAF757T                                                        2014/02/25 11:58:16
   3F9799  TORO1                                                          2014/02/25 17:17:41
* 3FA6BB  GAF121                                                         2014/02/25 07:09:46
   3FA6C6  PACK1                                                          2014/02/25 13:11:59
   3FAE9A        2014/02/25 08:22:25
   3FAE9A  TORO2                                                          2014/02/25 17:23:25
   3FF213  DMYGO                                                          2014/02/25 11:32:45
   3FF213  DMYGO                                                          2014/02/25 13:36:28
   3FF213  DMYGO                                                          2014/02/25 14:24:09
* 3FF281  DMOMR                                                          2014/02/25 11:43:46
   44069B        2014/02/25 19:50:16
* 4406F2  OEIGO                                                          2014/02/25 07:06:33
   440C85        2014/02/25 06:04:47
   445566        2014/02/25 17:00:38
   445566        2014/02/25 20:05:47
   44D106        2014/02/25 10:34:19
   45C94B  SAS1587  EKCH-ELLX                                             2014/02/25 07:29:43
   45C94B  SAS1588  ELLX-EKCH                                             2014/02/25 09:30:16
   45C94B        2014/02/25 11:47:20
   45C94B        2014/02/25 13:40:30
   45C94B        2014/02/25 19:24:38
   45C94B        2014/02/25 20:17:43
   4840DA        2014/02/25 14:27:50
   4843F6        2014/02/25 04:19:54
   4AC8D0        2014/02/25 08:32:48
* 4B19E9        2014/02/25 20:30:05
   4B843B        2014/02/25 00:18:55
* 4CA95C        2014/02/25 20:32:06
* 5081FF        2014/02/25 13:16:14
* 76EB57  MCT                                                            2014/02/25 13:23:26
* EC0075        2014/02/25 14:21:50
Monday:
* 00558A        2014/02/24 15:05:52
   3C0CA5  TUI9KX   EDDV-GCFV                                             2014/02/24 03:16:01
   3C0CA5  TUI53Y   GCFV-EDDV                                             2014/02/24 23:55:32
   3C48F7        2014/02/24 08:58:42
   3C4963        2014/02/24 18:40:29
   3C644C        2014/02/24 21:24:46
   3CCDD4        2014/02/24 08:52:53
* 3D2242  DELFM                                                          2014/02/24 08:32:02
* 3D2242  DELFM                                                          2014/02/24 14:40:10
   3D3873        2014/02/24 07:49:53
   3D3873        2014/02/24 11:55:19
   3DF014  DHLEA                                                          2014/02/24 14:27:35
* 3E8F00        2014/02/24 14:31:25
* 3E8F5C  FILTER                                                         2014/02/24 13:27:01
* 3E967F  KNIGHT2                                                        2014/02/24 09:53:41
* 3E967F  KNIGHT2                                                        2014/02/24 11:29:06
* 3EAC3F  JUSTIS                                                         2014/02/24 14:38:55
   3EADBA  GHOST                                                          2014/02/24 08:57:06
* 3EAE05  GAF775                                                         2014/02/24 07:46:33
* 3EAE05  GAF775                                                         2014/02/24 14:17:44
* 3EB0F5  POISON                                                         2014/02/24 16:21:15
* 3EBF1B        2014/02/24 09:20:20
* 3EBF1B        2014/02/24 14:41:06
   3F6926        2014/02/24 08:48:20
   3F6926        2014/02/24 12:53:23
   3F6926        2014/02/24 13:33:23
   3F759F  GAMG08                                                         2014/02/24 10:57:23
* 3F7DC3        2014/02/24 13:20:41
   3F820D        2014/02/24 09:19:17
   3F8D63  GAF139                                                         2014/02/24 08:22:48
* 3F9120  GAF963                                                         2014/02/24 14:40:45
   3F9191        2014/02/24 09:29:30
   3F9191  SPOOK                                                          2014/02/24 14:27:08
   3F969D  DASA07                                                         2014/02/24 13:32:40
   3FA6C6  SMASH2                                                         2014/02/24 08:33:30
   3FA6C6  SHOCK02                                                        2014/02/24 13:49:15
   3FAB16  GAMC14                                                         2014/02/24 07:41:12
   3FAB16  GAMC19                                                         2014/02/24 09:28:07
   3FAB16  GAMC19                                                         2014/02/24 10:49:55
   3FB280        2014/02/24 13:13:28
* 3FB298  NOBLE                                                          2014/02/24 09:44:02
   3FB6DD        2014/02/24 10:17:26
   44069B        2014/02/24 19:53:34
   445566        2014/02/24 13:14:24
   445566        2014/02/24 16:39:26
   445566        2014/02/24 17:34:53
   45C94B        2014/02/24 19:14:04
   45C94B        2014/02/24 20:19:43
* 4603DA        2014/02/24 19:31:16
   478385        2014/02/24 20:20:36
* 484153        2014/02/24 20:47:39
* 4B1610        2014/02/24 20:22:17
* 4B1A46        2014/02/24 20:29:19
   4B843B        2014/02/24 00:21:59
   4B843B        2014/02/24 21:32:36
* 8000CA        2014/02/24 10:39:41
Sunday:
   02A1AA        2014/02/23 08:14:40
* 396584        2014/02/23 11:58:39
   3C0CA5  TUI89C   EDDV-GCRR                                             2014/02/23 02:37:34
   3C0CA5  TUI7FC   GCRR-EDDV                                             2014/02/23 22:51:21
   3C48A0        2014/02/23 10:05:16
   3C4DD3        2014/02/23 17:35:36
* 3C5EA4        2014/02/23 05:39:02
   3D1B02        2014/02/23 12:56:05
   3D1CAF  DEJCP                                                          2014/02/23 12:19:36
   3D1CAF        2014/02/23 15:32:22
   3D3873        2014/02/23 09:52:46
   3D3873        2014/02/23 13:10:01
   3D3873  DETPZ                                                          2014/02/23 14:37:06
   3D3F16        2014/02/23 16:18:08
   3D4691  DEYYZ                                                          2014/02/23 09:58:53
* 3E6BE2        2014/02/23 11:36:45
   3F8D63  GAF139                                                         2014/02/23 13:59:52
* 3FF105  DMMJJ                                                          2014/02/23 11:58:29
* 3FF2BE  DMCFG                                                          2014/02/23 11:51:26
   445566        2014/02/23 11:59:13
   445566        2014/02/23 15:28:48
   445566        2014/02/23 19:33:30
   45C94B        2014/02/23 08:52:31
* 4784C4        2014/02/23 15:21:57
* 47A73C        2014/02/23 20:15:48
   4B843B        2014/02/23 21:50:59
* 4B8756        2014/02/23 23:57:30
   4BA907        2014/02/23 08:23:31
   4CA9DC        2014/02/23 12:33:37
   AD37D8  VELCRO5                                                        2014/02/23 10:23:03
