Started by orkney, January 27, 2014, 05:29:14 PM
Many thanks Niklas, all updates
CYYZGUY
Hi Alan
Mode S C08560
Flight ID CGYNF
No other fields populating.  I do know this is an Ornge Air Ambulance
regards,
Jason
40" LED Monitor
40" LED Monitor
CYYZGUY
Hi Alan, any info on this.
modes C00BA7
flight ID RS7488
This is showing up as Air Canada/Sky Regional Flight.  I see it almost every day but do you know why its flight ID is always "RS7488"?  Every other sky regional flight starts with "SKV"
Can you shed any information and possibly add routing?
40" LED Monitor
40" LED Monitor
CYYZGUY
ROU1819
ROU1787
No Routes
regards,
Jason
40" LED Monitor
40" LED Monitor
paul tricker
02010D is in DB as CN-MNH, should be CN-NMH
Paul
paul tricker
QFA2 shows as OMBD-EGLL-YSSY, first two need reversing
Paul
Jason,
C08560 C-GYNF AgustaWestland AW139 c/n 41226 7506406 Canada/Ornge Air
Jason,
ROU1819 MMPR-CYYZ
ROU1787 TGPY-CYYZ
Jason
RS is the IATA designator for SKV so I would presume the aircraft FMS is being loaded up using that code instead of the ICAO code.  The flight has also been noted using SKV7488 as that is already in the database as KDFW-CYYZ so I has also added it in using the IATA code.
I also note that the IATA designator was missing from the Sky Regional info in the Navdata so have added it in as well.
Morning Alan,
Just to advise you that the link given earlier to the Czech register appears to be working ok today.
Cheers Ian, they must have been working on it yesterday.
CYYZGUY
As always, thanks for your information and support here...
Jason
40" LED Monitor
40" LED Monitor
My pleasure Jason, you send me any blanks and I will do my best to fill them in, helps us all.
paul tricker
* 734D27        2014/03/04 13:15:24
* 734D27        2014/03/04 14:35:26
This decodes to EP-SIG which is an A300 c/n 750 of Meraj Air, currently in DB with its miscode only, so hopefully they have fixed both boxes!!
Paul
