Database Update Requests
Started by orkney, January 27, 2014, 05:29:14 PM
0 Members and 9 Guests are viewing this topic.
49524A CS-TRJ in d/b since14/3, thanks anyway.
Cheers Ian, thanks again.
CYYZGUY
BSK674
No Routing
regards,
Jason
2 Nm North from Canada's Busiest Airport CYYZ
DPD 1090 Mhz Antenna with LMR-400 Cable
Antenna 35 Feet (11 Meters) standing tall
Dedicated Airnav Station with 16 Gigs ram
Dedicated Radarbox24 Station with 16 Gigs ram
40" LED Monitor
40" LED Monitor
BCD996XT, BCT15X, BCT15X, BCT15 and BCD436 receiver
BSK674 is routing KOAK-KJFK Jason.
M
* 4677F8  T40A10      <- Ground Transmitter
Routes:
FCM1UX EFHK EETN
FIN4JL EFHK LJLJ
FIN5TV EFHK EFKU (Did you see reply #1290?)
PSW9559 ULLI EFHK
PSW9560 EFHK ULLI
M
SSF111 ULWC-EFHK (not ULBC-EFHK)
SSF112 EFHK-ULWC (not EFHK-ULBC)
The correct ICAO code for Cherepovets Airport (IATA: CEE) is ULWC.
http://skyvector.com/airport/ULWC/Cherepovets-Airport
http://www.acukwik.com/AirportInfo/ULWC
Many thanks again M.
Googling UBLC and ULWC both gives results for each as Cherepovets.  I presume UBLC was once the code for Cherepovets Airport?,  I have however deleted UBLC.
I must have missed 1290 as I haven't acknowledged it,  I have now included the routes detailed in it.
Judwin45
Hi Alan
9749C0 is an EH101 flying out of Westland, any clues on the identity.
Keith
5 miles south of EGDY
Keith, I believe it may be ZR335 an EH101 which in due course will go to Saudi Arabia
jacobite
Hi Alan, do you have any info on 780C31 thanks.
Ian,
A Scotavnet source gave it as B-3917 and H25B of NetJets Chin, no other info known
jacobite
Quote from: Runway 31 on April 17, 2014, 01:13:41 PM
Ian,
Thanks Alan.
vonsmalhausen
"49524A CS-TRJ in d/b since14/3, thanks anyway.
Alan"
are you shure about this ? I just reloaded a version of the DB after a update I did end of last week, but before I entered it manually : neither 49524A or CS-TRJ are found when I do a search.
if it is in the updates since 14/3, it should have been in that DB. see screenshot 1
I do have a further question, in the DB where I did the entry manually, there is a mark in the upper left corner of the MS cell, can you tell me what that means ? ( it can not be duplicate ) see screenshot 2
thanks for any enleightment ;-)
vonsmalhausen
another question, is 9H-AEI, the new "retroJet" of Air Malta already in the DB ?
I ask this because I can not find it in the DB ( see the screenshot ), and I did a update of the aircraft table just 10 minutes ago.
if it is supposed to be in the DB, I have a big problem regarding the updates
EK01
Evening Alan,
Another new Vueling route :
VLG6129 : LIRF-LEMD
Plus DAH3005 : LPPT-DAAG
