Author Topic: question regarding actype in DB  (Read 5146 times)
vonsmalhausen
« on: January 28, 2014, 09:47:52 AM »
as the title says, I have a question regarding the "actype" tab in the database ;
while working on my DB, I found N49JC in my photo folder who is not present in the DB, I also can't find the actype for a FM-2 Wildcat in the DB, so I want to ad it myself.
in the "actype" tab is a column called "AG" with J, P or T in it ; question is, where are these standing for, and witch would be appropriate for the Wildcat ?
vonsmalhausen
Re: question regarding actype in DB
« Reply #1 on: January 28, 2014, 09:56:15 AM »
just found out we have a WCAT code for Wildcats, so that's solved, but if somebody could explain the J,P,T entry's, that would be good to know.
« Reply #2 on: January 28, 2014, 09:57:45 AM »
N49JC was cancelled from the FAA list 22/3/2012 is now G-CHPN having arrived at Old Warden in a crate 02/2012 and was registered 23/05/2012.  It is a Grumman FM2 Wildcat c/n 5744 Richard Shuttleworth Trustee and is hex 406904 and is in the databse as such.
Its ICAO code is WCAT and is in the d/b as such.
« Reply #3 on: January 28, 2014, 10:02:18 AM »
From ICAO8643
Engine Types
J = Jet
P = Piston
T = Turboprop
E = Electric
vonsmalhausen
« Reply #4 on: January 28, 2014, 10:13:36 AM »
thanks for the quick answer and explanation,
renamed the picture, so it should be solved.
