radar box keeps disconnecting
Started by AV61, February 02, 2014, 08:12:52 PM
Just go to data find mylog and save it. Create a folder and drag it across into it and that will copy it.  When you have installed the fresh download do the opposite
AV61
AV61
Ok so I delete radarbox via control panel delete program
I reload via full installation link on form
I start to run it and it doesn't load past  rB1-found
I try again with USB out and this time it does load
It has loaded with all my original settings and log etc
Why is this when I deleted and started afresh
Also any clues as to the not loading with the USB lead in
Nick
Deleting through Control Panel doesnt delete everything, you normally have to get in there manually and elete what is left.  Thats not just true with Airnav but also most programs as the process normally leaves orphan files behind.
Support may be better placed to discuss your problem with as they have the technical knowledge.
73TORANA!
I had the exact disconnect Issue with my box purchased in 2009 and it was the poor quality USB lead supplied . Airnav notified but it looks like they still maybe supplying cheap leads ??
