Author Topic: AirNav RadarBox 5.00.71 - Download Available  (Read 37793 times)
Re: AirNav RadarBox 5.00.71 - Download Available
« Reply #30 on: March 03, 2014, 08:31:48 AM »
Ian, you must close down.  The installer would note if RB was running and would advise to close down first.
jacobite
« Reply #31 on: March 03, 2014, 08:41:08 AM »
Thanks Alan. I have just updated and all seems to be working fine.
« Last Edit: March 03, 2014, 08:56:58 AM by jacobite »
GreekSpy2001
    • Graham's Aircraft Photos
« Reply #32 on: March 03, 2014, 09:34:23 AM »
just to add.  Just downloaded and installed ver 0071 and have the double flight ID in my alert pop ups.  Makes the alert pop up very wide.  See attached screen shot.
Graham
« Reply #33 on: March 03, 2014, 11:23:27 AM »
Hallo Alan,
the freecing of flight could have been related to an installation of a windows security patch, performe by windows update without my permission. During regular operation I haven't had any flight freeces so far.
« Reply #34 on: March 03, 2014, 11:26:33 AM »
Thanks Ingo,
We havent noted any problems so would be obliged if you could advise if and when it occurs again.
« Reply #35 on: March 03, 2014, 11:28:44 AM »
WILCO, but may take some time.
« Reply #36 on: March 03, 2014, 11:29:07 AM »
Jonathan, please advise when it occurs again, we are not seeing any problems.
« Reply #37 on: March 03, 2014, 11:29:44 AM »
No problem Ingo, hopefully you will not need to contact re this issue.
shouriken
« Reply #38 on: March 09, 2014, 08:15:18 AM »
I confirm that the "Mylog/Grids/Populate" was not fixed.
As the first post of this topic says
Quote
All pending bugs corrected except:
- Erroneous altitude reported after timeout
I'd expected to be fixed.
Liviu
A.net JetPhotos.Net
RadarBox
« Reply #39 on: March 09, 2014, 09:21:16 AM »
Populate has been fixed will be in the next version and the erroneous altitude issue is being worked on at this time
PatW
« Reply #40 on: March 09, 2014, 05:40:08 PM »
I am going with version 3.13, could someone advise the easist way to get up to date, I assume that I will need to remove version 3.13 and start again with the newer version but how many additional downloads are there after the re-install.
Thanks for any advice
Pat
« Reply #41 on: March 09, 2014, 05:57:03 PM »
Pat,
Yes uninstall 3.13 but save your mulog, photos etc for re-use withthe new vwrsion and replace them after installation.
The last full install was for 5.00.65 here http://www.airnavsystems.com/download/ANRB/ANRB50065Setup.exe
Then upgrade to the latest 5.00.71 here http://www.airnavsystems.com/download/ANRB/ANRBUpgradeto50071.exe
PatW
« Reply #42 on: March 09, 2014, 11:07:21 PM »
Thanks for the assistance
Pat
Jonathan.G
« Reply #43 on: March 15, 2014, 11:49:34 PM »
@Alan, i got a freeze today. (ANRB 5.00.71)
Screen : http://img15.hostingpics.net/pics/609616freeze.png
« Reply #44 on: March 16, 2014, 08:43:59 AM »
Jonathan,
We would need the eureka log or other error report or log to see what is happening on your system.  Its very hard for a diagnosis otherwise especially when others are not experiencing the same.
« Last Edit: March 16, 2014, 09:08:57 AM by Runway 31 »
