AirNav RadarBox 5.00.71 - Download Available
Started by AirNav Development, February 26, 2014, 07:42:49 PM
0 Members and 5 Guests are viewing this topic.
Ian, you must close down.  The installer would note if RB was running and would advise to close down first.
jacobite
#31
Quote from: Runway 31 on March 03, 2014, 08:31:48 AM
Thanks Alan. I have just updated and all seems to be working fine.
GreekSpy2001
just to add.  Just downloaded and installed ver 0071 and have the double flight ID in my alert pop ups.  Makes the alert pop up very wide.  See attached screen shot.
Graham
neroon79
Hallo Alan,
the freecing of flight could have been related to an installation of a windows security patch, performe by windows update without my permission. During regular operation I haven't had any flight freeces so far.
Ingo
11.75nm ESE of EDDV
HW:
Cable: 25m of ECOFLEX 15+
NB: Asus P53E 24/7 op.
PC: 28"4K + 24" Monitor
AirSpy mini @RPi3
Thanks Ingo,
We havent noted any problems so would be obliged if you could advise if and when it occurs again.
neroon79
11.75nm ESE of EDDV
HW:
AirSpy mini @RPi3
Jonathan, please advise when it occurs again, we are not seeing any problems.
No problem Ingo, hopefully you will not need to contact re this issue.
shouriken
I confirm that the "Mylog/Grids/Populate" was not fixed.
As the first post of this topic says
QuoteAll pending bugs corrected except:
- Erroneous altitude reported after timeout
I'd expected to be fixed.
Liviu
A.net JetPhotos.Net
RadarBox
2xRTL USB + Franklin+Collinear antenna + PlanePlotter
Populate has been fixed will be in the next version and the erroneous altitude issue is being worked on at this time
PatW
I am going with version 3.13, could someone advise the easist way to get up to date, I assume that I will need to remove version 3.13 and start again with the newer version but how many additional downloads are there after the re-install.
Thanks for any advice
Pat
Pat,
Yes uninstall 3.13 but save your mulog, photos etc for re-use withthe new vwrsion and replace them after installation.
The last full install was for 5.00.65 here http://www.airnavsystems.com/download/ANRB/ANRB50065Setup.exe
Then upgrade to the latest 5.00.71 here http://www.airnavsystems.com/download/ANRB/ANRBUpgradeto50071.exe
PatW
Jonathan.G
#44
Jonathan,
We would need the eureka log or other error report or log to see what is happening on your system.  Its very hard for a diagnosis otherwise especially when others are not experiencing the same.
