Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
AirNav Systems Forum
AirNav Radar Discussion
(Moderator:
Why has this started happening?
« previous
next »
Print
Pages: [
1
Author
Topic: Why has this started happening? (Read 3501 times)
jetset
Full Member
on:
February 27, 2014, 10:40:37 PM »
I'm getting flights down to about 800ft and obviously losing them.
But then, instead of just sitting there at 800ft, they suddenly appear as being at FL160 then FL380 before they eventually time-out!
I'm using win7 64bit and 4.03
Logged
Steve
Moderator
Hero Member
Re: Why has this started happening?
Reply #1 on:
February 27, 2014, 11:08:27 PM »
That erroneous altitude has always happened and is still to be fixed. The signal given off changes around 3-400ft and then again when the aircraft is on the ground.
Last Edit: February 27, 2014, 11:11:36 PM by Runway 31
Logged
jetset
Full Member
Reply #2 on:
February 27, 2014, 11:30:45 PM »
Oh. Never noticed it before.
Logged
Steve
jetset
Full Member
Reply #3 on:
February 28, 2014, 05:41:33 PM »
Actually, I have remembered distinctly watching planes land at Luton and Heathrow in the past when I've swapped/altered height of my antenna for a comparison.
This never happened then. They used to get to how ever many feet and just time out.
Logged
Steve
Moderator
Hero Member
Reply #4 on:
February 28, 2014, 05:55:36 PM »
Please look back through posts and you will find it mentioned often enough. It doesnt occur on every flight but it does occur. It will be the last of the original bugs to be fixed.
As an example havea look at
http://www.airnavsystems.com/forum/index.php?topic=4987.msg49961#msg49961
Last Edit: February 28, 2014, 06:06:59 PM by Runway 31
Logged
jetset
Full Member
Reply #5 on:
March 01, 2014, 12:10:51 AM »
It's never occurred for me until now. I've not had the box running for nearly a year but I'm still using the same software.
If as you say, this is an original bug, then why is it being one of the last ones to fix?
It's quite a major one isn't it?
Logged
Steve
Moderator
Hero Member
Reply #6 on:
March 01, 2014, 07:55:17 AM »
Maybe because it is the hardest to fix!!
Logged
Print
Pages: [
1
« previous
next »
(Moderator:
