Database request
Started by paul walker, March 01, 2014, 10:24:25 AM
paul walker
Have upgraded to 5.071 and working ok but after spending hrs updating the database an putting * next to the regs that I have seen the next time I restart the box all the work I have done has gone is there a way of stoping this
rgds p walker
#1
Are you recording these as manually updated by changing Y to N and also unticking update manually changed records in Preferences/Radarbox  Also when doing a Navdata Update are you using Do not Update Manually Changed Records?
Also when you close down RB are you using File/Exit?
paul walker
#2
yep done that have just restarted the box and the 2 regs I just put a * against to test have gone back to the way they was and Y is back where I changed to N
was not using file/exit  testing now
nope alan still not saving the changes
Always use File/Exit to close down as nothing is saved if tyou just use the red X
Where are you putting the *
paul walker
Paul,
That will not work.  Use the CO field in the aircraft record for any annotations
paul walker
nope not worked either and have changed the Y in the autoupdate field to N and on restart is still going back to Y
I will need to get back to you
#9
Paul,
Sorry for the delay.  After waiting 15 minutes, she who must be obayed was becoming increasingly irrate at me telling her I am just coming when she was wanting me to take her into town!
Put the * into the CO box then press somewhere else on the grid to set the change, the same when you change Y to N
All manual changes to d/b explorer require this.
Judwin45
I have been using the 'CO' column for several weeks to record those aircraft that I have visually seen.
When an aircraft comes up on 'My Flights' I go to the database and put a 'yes' or 'no' in the CO  box, change the Y to N and then click somewhere else on the line.
Next time the aircraft appears in My Flights the yes or no is there in the CO box.
The only thing I have found is that it is not instant. Although I change the data base if the aircraft is still showing in my flights it will not reflect the yes or no until the next time that aircraft appears, but I can live with that.
The 'CO' box is a good step forward for the 'visual spotter' like me.
I just wish I could delete more than one record at a time in the data base.
Keith
5 miles south of EGDY
I know that feeling well Keith.  I have to delete everything individually as well.
paul walker
played around with it all night still cant get it to save the changes I make put yes in the CO field and change Y to N shut down the system and re start and its all back to the same as before
Paul,
Open up d/b explorer/Aircraft.  Go to the top one N998HG, scroll along to CO field, click on it, then edit cell, the blue box changes to white, enter *, click on one of the pink boxes.
Scroll along to autoupdate, click on the Y, then edit cell. blue changes to white, change the Y to N then click on one of the pink boxes, close d/b explorer.
File/Exit to close down RB.
Restart and check the CO field on N998HG and what is in it.
paul walker
my first reg is 00-0171 c17  put  * in the co field and Y in the autoupdate field pressing in blank pink boxes in between shut down and re started and its the same as before
paul
