Author Topic: Looks like my RB didn't survive first thunderstorm of the year  (Read 14486 times)
Kenny
We just had thunderstorm this afternoon.  When I've got home, my RB range reduces to less than 20nm where  I normally get around 200nm.
Hope it is from wet coax not circuit damage.
In the mean time, apologize for limited range around Bangkok.
Kenny
« Last Edit: April 28, 2014, 03:33:24 PM by Kenny »
ANRB 3km north of VTBD
Re: Looks like my RB didn't survive first thunderstorm of the year
« Reply #1 on: April 28, 2014, 03:48:46 PM »
Doesn't sound good Kenny.
    • Rod's RadarBox Downloads
« Reply #2 on: April 28, 2014, 04:03:48 PM »
Good luck, Kenny
Hope it does dry out OK.
« Reply #3 on: April 28, 2014, 04:19:21 PM »
Kenny,
Suppose it's a bit late now to tell you but ALWAYS pull out the antenna connection if thunderstorms are forecast to be in the area.
« Reply #4 on: April 28, 2014, 07:37:21 PM »
Lightning arresters are available, but I'm not sure just how effective they are in protecting RBs, they seem to work OK for GC Receivers though.
« Reply #5 on: April 29, 2014, 05:33:27 PM »
About arresters: They work quite well for secondary lightning discharges or strong electrostatic charges, that are build up shortly before lightning strikes*. During this effects of thunderstorms you can sometimes already smell the ozon, but you don't get the full hit. If you catch a full hit (primary lightning discharge) they are useless as all equipment between lightning entry poitn and ground/erth gets fried. I've some experience with satellite equipment and terestrial TV and lightning causing electronic toast.
* The flash-channel starts building up, but the channel building up from your antenna isn't the one that does ignite through.
Kenny, I hope that it is just a drowned Coax connection.
Regards Ingo
« Last Edit: April 29, 2014, 05:37:12 PM by neroon79 »
Kenny
« Reply #6 on: May 04, 2014, 01:51:09 AM »
Just an update.
Swap RB with DVB-T dongle and run RTL1090, the Msgs/Sec jumps from around 15 to 150 and see a whole lots aircraft.
Kenny
« Reply #7 on: May 04, 2014, 12:48:24 PM »
Ingo, thanks for the extra info.
Kenny
« Reply #8 on: May 11, 2014, 06:04:00 PM »
I will be offline for sometime until it is come back from repair.  During this time I'll using DVB-T dongle and RTL1090.  For sure, I'll miss the RB interface.
Kanok
« Reply #9 on: May 11, 2014, 06:41:06 PM »
Hi Kenny,
Thanks for the update, missing your input, I hope it is a quick turn round.  Are you able to input into the network with the dongle?
Kenny
« Reply #10 on: May 11, 2014, 09:25:41 PM »
Hi Kenny,
I know AirNav has upload client for other hardware, how to get one?
Kenny
« Reply #11 on: May 12, 2014, 07:13:33 AM »
Leave it with me Kenny
Kenny
« Reply #12 on: May 13, 2014, 12:07:52 AM »
« Reply #13 on: May 13, 2014, 07:18:13 AM »
Kenny, see PM
Kenny
« Reply #14 on: May 17, 2014, 02:47:31 AM »
Contact support and they gave the link for client download.  Asked to give them the Sharing ID once installed to activate the account.  ID & email sent several days.   Still quiet.
Kenny
